Results 201 to 210 of 5870
August 19th, 2012 09:28 PM #201
Can anyone check if there is reverse sensors for the GLS? The Eco/Econo button is probably from the Honda Civic/CR-V and not the Mirage. Mirage is already an economy car so no point in adding an Eco button.
August 19th, 2012 11:20 PM #202
- Aug 2012
- 23
August 19th, 2012 11:22 PM #203Hello! We too, already made a reservation for a GLX M/T last Friday. As an everyday car, we chose to, hopefully, buy this car kasi sulit na price neto sa mkkha mong kotse + features of it (esp the dimensions of the car, puedeng puede pang car pool.hehe). i just hope na totoo talaga na may ABS+EBD yung GLX M/T variants para sulit na sulit na tlga cya.
We really just hope di magkaron ng problema pag nasa buying stage na talaga....wag sana tayo tagain nang Mitsu like what Toyota did when they released the Fortuner for the very 1st time a few years back...hahaha! =)
Just a question lang po, my understanding is the 40k early bird discount is the promo of the Mistu plant itself, not of the dealers, so does it mean we still have a chance to have a much lower price if ever magbibigay pa nang addtional discount ang mga Mitsu dealers?
Lastly, yung 15k na discount for the accessories, is it on top of the normal accessories given by the dealers (seat cover, tint and floor mats)?
Thank you!
August 20th, 2012 12:52 AM #204
From my MIAS visit last Thursday...
The local Mirage will not have ABS/EBD nor start/stop technology to make pricing attractive, with the hi-end GLS CVT priced at 638K. The display unit was already a left hand drive model. 8 colors will be available by Nov 2012. With its features and base GLX 5MT unit priced at 498K, this will pose a new threat to other car models in the same price range. But I wish they would release the Mirage 1.0 GLX 5MT with start stop to push the fuel efficiency up to 30 kms per liter.
Was able to test drive the MiEV as there were no Mirage unit available. The MiEV was super fun to drive. Super silent and can hit 80kph in 8 secs. Almost got caught on a 60kph speed limit at Macapagal :-) I think Mitsubishi will be the new leader on eco-cars!
2012 Mitsubishi Mirage (codename EL = Entry Level)
Price (as of August 16, 2012 * MIAS 2012)
GLX MT - 498K
GLX CVT - 548K
GLS MT - 588K
GLS CVT - 638K
Engine 1.2-litre three-cylinder engine (3A92)
Fuel System ECI-MULTI
Displacement 1193 cc
Bore x Stroke 75 x 90 mm
Compression Ratio 10.5 : 1
Max. Output 78 PS / 6000 RPM
Max Torque 100 N-m / 4000 RPM
Fuel Tank 35 Liters
Fuel KPL 21 kms per liter (*MMC test results usig EU Combined Cycle)
LxWxH 3710x1665x1500
Wheelbase 2450mm
Ground Clearance 160 mm
Turning Radius 4.4 meters
Curb Weight: 820 to 850 kgs
Tranny Gear Ratio 3.545 to 0.804 (5MT) / 4.007 to 0.550 (CVT)
Final Gear Ratio 4.055 (5MT) / 3.757 (CVT)
Tires & Wheels
GLX 14" Steel with Full Wheel Cover and 165/65 R14 Tires
GLS 15" Alloy with 175/55 R15 Tires
Suspension
GLX MacPherson Strut Coil Spring
GLS MacPherson Strut Coil Spring with Stabilizer
Steering
GLX 3-Spoke Urethane
GLS 3-Spoke Leather Wrapped
Aircon
GLX Manual Control
GLS Full Auto with Climate Control
COLORS
Lemonade Yellow Metallic
Pop Green Metallic
Majestic Red
Medium Blue Metallic
Savannah White
Cool Silver Metallic
Eisen Gray Mica
Pyrenese Black
Standard Items (GLX & GLS)
Front Dual SRS Air Bags
Front 3P ELR Seatbelts with Pre-Tensioner and Adjustable Seatbelt Anchor
Multi-Info Display (trip computer)
INVECS-III CVT or 5-Speed MT
235 Liter Cargo Space
Rear Wiper & Washer
Rear Window Defogger
Roof Mounted Antenna
LED Type 3rd Brake Lamp
Laminated Green WIndshield
Side Impact Beams
Child Proof Lock
Additional Features (GLS only)
Rear Tonneau Cover (hard top)
Keyless Operation System + Engine Start/Stop Button
3rd Rear Seat 3-point ELR Seatbelt
High Grade Fabric Seats
Rear Spoiler
August 20th, 2012 12:57 AM #205
It would be strange for the Mirage not to have ABS considering it has dual airbags. Car companies usually remove the airbags first then ABS if they wanted to lower the price. Back read a page or two, the MMPC brochure they gave out indicates there will be ABS+EBD for GLS models.
- Jul 2012
- 88
August 20th, 2012 03:02 AM #209
Funny thing I saw a while ago at the 4th PIMS. The Mirage uses Bridgestone Potenza RE050A's. Yep. The same tires that cars triple its price (e.g. Genesis Coupe) use.
- Jul 2012
- 215
agree ako syo. battery dying will be the next owner's problem. kaso the only reason I'm buying...
All New Toyota Corolla Cross
