Results 31 to 40 of 45
March 21st, 2014 12:34 AM #31
Kung steering clamp, easy fix lang siya. The clamp is what holds the steering rack in place. Goma siya that wears out over time. Nun walang clamp na available, inipitan na lang muna namin ng ginupit na timing belt as a quick fix.
- Jul 2011
- 1,711
March 21st, 2014 04:58 AM #32
March 21st, 2014 11:29 AM #33
same din before sakin bro, kala ko normal sa gas yun kase dati de diesel ako kaya diko pinapansin pero katagalan lalong lumalakas. kaya nung pina tsek ko sa mekaniko ko ang problema e yung transmission, clutch cylinder assembly. kaya nung na repair naging smooth na yung pag shift nya. para sigurado pa tsek mona din sa magaling mong mekaniko para makasigurado ka. lalo pa at necessity ang sasakyan ngayon.
- Mar 2014
- 22
March 22nd, 2014 12:00 AM #34
- Mar 2014
- 22
March 22nd, 2014 12:02 AM #35sir ask ko lang po san banda un? at may address or tel. no. kyo at para madala ko ung advie, maraming salamat po
- Mar 2014
- 22
March 22nd, 2014 12:04 AM #36
March 22nd, 2014 08:51 AM #37
- Mar 2014
- 22
March 27th, 2014 03:52 PM #38sir OTEP na pa check ko na po kay mang dick ung advie, madami sya gawa pero sinlip nya rin nag higpit sya sa mga pang ilalaim at medyo humina at dumalang ang naririnig kong TOK sound. snana nga un lang, ok pa na man daw ung mga steering clamp mahihigpit daw. at may inalok sya pa porma ko daw ng konti ung pwet pataasin papalitan daw ng leaf spring hanger ok ba un
March 28th, 2014 12:17 AM #39
- Mar 2014
- 22
March 31st, 2014 11:55 PM #40[QUOTE=OTEP;2334499]Pinadala din po dun black adventure ng boss ko last wednesday. Palit rear shocks. If ok naman rear suspension, huwag na muna galawin
Sir OTEP, musta po sya nga pala ung TOK sound pina remedyohan ko sa EL Dorado kasi ang problema daw ung steering coupling. ung bago pala un eh nasa 9k wala pa labor. ngayon si sir ferdi nakausap ko pwede naman daw remedyohan at tumatagal din naman si jay ung gumawa, sa ngayn wala ako na ririnig na at lumabot ung manubela ko.... ask ko lang po ok naman kaya un...
just seen a 10th gen cross 200,000 miles on reddit. is this a unicorn or has the cvt been proven...
All New 2016 Civic
