Page 469 of 501 FirstFirst ... 369419459465466467468469470471472473479 ... LastLast
Results 4,681 to 4,690 of 5002
    #4681
    I have already inquired ATCO-Zapote, Mitsu Prime-LasPinas, El Dorado-Cubao. Wala daw silang aux fan complete assembly. Ang meron sila yun fan motor lang. Yun isang nagpakabit dito sa casa bumili at nagpakabit.
    Jul 2014
    #4682
    Quote Originally Posted by doy View Post
    Php 739.20 lang ang EGR cleaning. This is according to Mitsubishi Ozamis (Fast Autoworld Phils. Corp. - Ozamis) manager. Kaya yan linisin ng mechanic outside the casa. Pero kailangan mo siya i-instruct kung ano tatanggalin at linisin (research nalang sa net like Triton.net). Php 300 lang yan.
    Mga boss good day. I also experienced stalled engine sa Strada when shifting to 3rd gear and also no engine response kahit tapak ko na ng husto yung throttle (often occurrence lang po).. Then naimbestigahan ko siya try ko patayin yung aircon when this happens and all of a sudden its back to normal engine response, i tried it for 2-3 times and still same effect. Tanong ko lang po kung may epekto kaya yung aircon sa issue na to? And PLEEEEASE, tell me what is EGR and SCV? im sorry pero wala po akong idea kung ano yun. I also change my iol, air and fuel filters, oil change, but still after a week nageexist pa din yung no response ng engine. If someone could insert an image of egr or scv much better po..
    I hope someone could help us out of this problem before namin ipadala sa casa which may be costly.
    Thank you mga sir/mam/boss!
    Mar 2012
    #4683
    Quote Originally Posted by supergado View Post
    I'm no expert but hindi kaya naka tsamba ka nang dirty fuel? na experience ko na before yan. I don/t think the aircon has anything to do with the engine stalling. About sa 3rd gear naman I had a broken 1st, 3rd and reverse gear before but hindi naman nag stall yung engine. But still your best bet is to bring your rig to a casa/serviek for OBD checks.
    just to give you an overview
    note: this is taken from a 4m41(non-vgt) engine but for presentation purpose only, it is almost the same as the 4d56 engine.
    EGR-The exhaust gas recirculation (EGR) system lowers the nitrogen oxide (NOx) emission level.
    When the air/fuel mixture combustion temperature is high, a large quantity of nitrogen oxides (NOx) is generated in the combustion chamber. Therefore, this system recirculates part of emission gas from the exhaust port of the cylinder head to the combustion chamber through the intake manifold to decrease the air/fuel mixture combustion temperature, resulting in reduction of NOx. The EGR flow rate is controlled by the EGR valve so as not to decrease the driveability.
    SCV- also known as suction control valve (well its elf explanatory na )
    #4684
    Quote Originally Posted by Lex_Mari View Post
    Hello everyone! A not so new member/parokyano ng tsikot forum here.
    Just want to share and query na din guys - ours is a 2010 3.2L GLS 4x4 strada. it is already nearing its 100k odo and is scheduled for a heavy pms next week. One of the pricy item I have notice from my service advisor's tentative quote is that of the timing belt change which is around Php19k. The quote was given even without sa advisor verifying my engine. Nor did he ask kung ano variant ng strada ko.
    I once encountered dito sa strada forum (di ko na mahagilap page number) a member stating that 3.2L variants carry the 4m41 engine type and as such is equipped with a timing gear/chain (instead of belt which is replaceable every 80k to 100k pms).
    Tanong ko lang sa mga Strada 2010 3.2L owners - 1st. Is the claim that our 3.2L strada (4m41 engines) have timing chains true? and 2nd. If the first is true, kelan sya (timing chain) dapat palitan? Pasencya na mga sir, am really not so familiar sa mitsu engines . I'm learning just as my strada aged and I find this 1ook pms so crucial as my beloved pick-up have not yet encountered any major problem/repair. TIA guys sa advice.
    atty. , timing chains ang 4m4 family(4m40/41) baka naoverlook lang ng service advisor mo.
    #4685
    You may start by downloading 4D56/4M40 CRDI fuel system (Denso HP3) manual here.
    Denso Fuel System_Mitsubishi_triton
    http://diesel-art.com/manuales/Mitsubishi_triton6Ad.PDF
    SCV at section 4.2
    HTH
    #4686
    Pwede ba na hindi sa casa mapapalit ng timing belt? Ang mahal kase e..my mabibilhan kaya ng timing belt for strada 2.5? Saan kaya at magkano?
    Jun 2013
    #4687
    Mga Sir good morning,
    Ask ko lang ano kaya yun umiingay sa makina ko na kapag apak mo clutch nawawala, pero normal naman yun unit, hindi mahirap sa clutch or mag shift ng gear.
    sa mga belt kaya yun? pasensya na po wala ako alam sa makina.
    Jun 2013
    #4688
    Update:
    Tumawag po ako sa Mitsubishi, transmission daw po sira, yun nga po ba yun? 1yr and 2 months pa lang yun unit ko
    #4689
    Quote Originally Posted by fourstring View Post
    Yung ingay na parang squeal at nawawala pag naka depress ang clutch na experience ko rin before, they just greased the clutch fork/release or something? Sorry na kalimutan ko yung exact term. Yun nawala na.
    Jun 2013
    #4690
    Quote Originally Posted by jubs00 View Post
    Yun para bang fan belt na kulang sa langis ang ingay, na tapakan mo nga lang clutch nawawala, kahit konting tapak mo lang sa clutch nawawala yun ingay.
    Pero nagsearch ako dito meron akong nakita same na same dun sa problema ko pero sabi dun ang pinalitan daw eh clutch disc.
    Sabi sa Casa nun itawag ko ibababa daw transmission
2010 Mitsubishi Strada [continued 2]
