Page 404 of 501 FirstFirst ... 304354394400401402403404405406407408414454 ... LastLast
Results 4,031 to 4,040 of 5002
    Apr 2008
    #4031
    Quote Originally Posted by RealAmbro07 View Post
    Ay sorry sir, mine kasi is 4x2 glx v. Pwede ba yung rim nun for 265/65R17
    16 inch lang ata yung stock rims ng 4x2? If you're still gonna use that, you'd have to get 265/70/R16 tires, same size as the Pajero Fieldmaster's.
    Sent from my GT-I9100 using Tapatalk 2
    Oct 2013
    #4032
    Thanks sir for the info. Kapag nilagay po ba yung 265/65/R17 na gulong kailangan na rin ba ng lifter at sasayad kaya siya. Thanks again
    Apr 2008
    #4033
    Di naman siguro bro. That's the stock size of the Montero AFAIK, so there should be no problem. Kapag siguro mga above 20 inchers na bago ka mag-alala sa pagsasayad.
    Oct 2013
    #4034
    Quote Originally Posted by GTi View Post
    Thanks GTi sa info. Hopefully di ka mag sawa sa pagsagot sa mga inquiries
    #4035
    ///IPF? SUPER OFF-ROADER
    ///IPF? 900 DUAL BEAM
    ask ko lang kung may nakagamit na sa inyo ng ganito. namimili kasi ako between the 2 para dagdag ilaw. baka may mabigay kayong feedback.
    gusto ko kasi sa dalawang to is may hi/lo option, though magkaiba ang beam pattern nila. ok sana yung super offroader kaso di ko alam gaano kalayo ang range nung ilaw. sa dual beam kasi may range sya na 50m sa lo, at 200+ sa high.
    Jun 2013
    #4036
    Mga Sir question lang, may inorder kasi akong fender flare ganito sa pic below dito sa province, ask ko lang kasi plastic palang yun inorder ko similar sa pic below ano po ba ginagawa dun? Sabi ko kasi Matte Black gusto ko color, ask ko kung mamaselyahan pa yun sabi nun inorderan ko hindi na daw, lalagyan lang daw ng first coating ba yun then yun ng Matte Black.
    Talaga po bang ganon lang? Wala po bang maselya yun ganun?
    Thanks.
    Apr 2010
    #4037
    Re: 265/65R16 tires on GLX rim
    Just a word of caution. AFIK masyado na malapad ang tire na yan. The safest it can go is 235, i think. GLX rim is just 16x6. Compared to usual offroader of 16x7.5+ However, I know that some put wider tires. Hence, think and research more and consider safety over looks. Just my 2 cents.
    Apr 2010
    #4038
    Quote Originally Posted by fourstring View Post
    Thanks.
    Kung maganda naman ang pagka-finish pede na walang maselya. Pero I suggest to use primer (use the right primer for the base material and paint) pa rin. Mas maganda kapit kapag me primer.
    Jun 2013
    #4039
    Quote Originally Posted by ezrydre View Post
    Primer nga pala yun sabi nun gagawa,
    Thanks Sir, sabihin ko na lang gandahan ang gawa.
    Jun 2013
    #4040
    Sa akin ganyang ganyan yung pinalgay ko. Pinapapaint ko sa kanila ng flat black kaso di daw sila nag papaint, kung gusto ko daw pylox spray paint na lang muna pang samantala para lang daw di panget tingnan pag kinabit nila.. ipapaint ko na lang daw sa iba... so far ok pa naman.. pinatungan ko na lang ulit ng paint sa bahay para kumapal at ng clear na coating.. puro spray paint lang yun.
2010 Mitsubishi Strada [continued 2]
