Page 389 of 501 FirstFirst ... 289339379385386387388389390391392393399439489 ... LastLast
Results 3,881 to 3,890 of 5002
    Jun 2013
    #3881
    ^^^Di ko lang sure boss.. Pero before parang may nabasa ako na nag palit ng gulong tapos yung stock rims pa rin gamit nya nya.. Inquire na lang kayo sir sa mga tire shop para sigurado...
    Guys, advisable ba na iblank agad ang egr kahit bago pa ung sasakyan? sigurado void agad yung warranty nun right? If ever mag light yung check engine, mawawala ba yun pag tinanggal yung pangblank?
    Mar 2012
    #3882
    Quote Originally Posted by RF02 View Post
    up lang po mga sir :D
    judging from the size of tire na ikakabit mo i guess na 16" din yung stock mo. If i'm not mistaken yung rim mo is 16x6. yung minimum safe width sa tire size na gusto mo is 7 ata so parang di pwede yung size na gusto mo sa stock 16"rim.
    I posted the same question sa tscp fb page. The guys(mga naka blank na) told me na if possible wag muna and sagarin na muna ang warranty. Dahil i'm sure dami na namang issue ang casa nyan if they found out the blanking plate. But if your not worried about warranty issues then its your call.
    #3883
    Quote Originally Posted by ezrydre View Post
    sir, reseat, tanggal tas balik ulit. hehehe.
    if you have other electrical addons try to check the grounding.
    Thanks sa reply sir.. Busina lang naman ang binago pa lang sa strada namin at na try ko narin tanggalin fuse nya saka i bukas yung headlight at wiper pero ganun parin kaya ibig sabihin hindi sa busina problema..
    Jul 2013
    #3884
    Quote Originally Posted by D3nb3r View Post
    ahh, anong specs po kaya pinaka-malaking goma na pwede sa 16" ko po?
    Apr 2010
    #3885
    Quote Originally Posted by kingtooth View Post
    I think it's time to swap your bulb. or probably remove first the problematic bulb. then check yong high beam indicator. btw, 2 filament ying bulb. so pede mo rin ma bench test pag natanggal mo na. baka di na nagana yong high.
    Mar 2012
    #3886
    naku napakarami nang mga brands, types and specs for a tire. you can check out their website and usually meron sila mga tables dun para ma base mo ang tire size na gusto mo based on your rim. Also hindi advisable na i sagad mo ang tires size sa rim mo like for example: 16x6 rim then you get a tire that has a rim fitment of 6. that means sagad na cya and wlang allowance. Sa Cooper tires S/T all-terrain pwede ka ata sa 215/85/16 dahil 5.5-7 allowable rim dun.
    Try checking this site Offroaders.com Source for 4x4 off-road trail reports, tech articles, 4x4 clubs, Product Reviews pra hindi ka na pa talon-talon sa mga tire maker's site. almost lahat nang tire brands, type usage ay andyan. Very informative ang site na yan. almost every info on tires ay andyan na. you can also some get reviews, tips and pointers din.
    Jul 2013
    #3887
    wow thanks so much po sir ah dami ko natutunan sa inyo po :D
    Jul 2013
    #3888
    mga sir medyo parang tanga lang yun tanong ko ah... sorry pero hindi ko kasi talaga alam... hehe
    pag park mo tapos let's say maiiwan ka sa loob dahil yun kasama mo lang may bibilhin saglit sa tindahan,
    edi papatayin mo makina tapos bbuksan mo bintana diba?
    kaso bakit ganun kapag ni-lock mo sa loob yun door mo nag aactivate yung alarm? (tutunog TuuT) tapos kapag nag unlock ka sa loob din mag aalarm na...
    ang hassle kasi eh ang ingay ni strada...
    paano kaya i-lock toh ng hindi mag aactivate yun alarm po?
    up on this,
    I tried kanina i-ACC tapos lock ko sa loob nag aactivate parin yun alarm eh
    pano kaya to i-lock mga sir kagaya ng ibang sasakyan na hindi nag aactivate yun alarm po?
    Apr 2010
    #3889
    *RF02
    just tried your case.
    engine off; key on acc position. lock/unlock from inside = no alarm
    pero kapag naka off ang key position mag aalarm talaga...
    also, usually kapag me iiwan ako sa sasakyan, naka on para me aircon naman sila.
    hth...
    Jan 2011
    #3890
    nag pa install na me ng Oil Catch Tank/Can sa S4S sa QC. Then just had my 5k PMS too.. Nakabili na rin ako ng Aeroklas Utility Box sa Banawe Goldcars.. Cabin Filter naman pag may time, at pera pa hehe.
    parang never ending ang pag gastos pag may pick up ha.
2010 Mitsubishi Strada [continued 2]
