Results 3,091 to 3,100 of 5002
March 20th, 2013 05:13 PM #3091
- Sep 2008
- 120
March 20th, 2013 06:14 PM #3092Pinasok ko na sa Casa at sinabay ko na sa whistling issue ng manibela ko (another issue I encountered a few weeks back but was not satisfctorily repaired by the Casa). Good thing kasi papalitan na daw nila steering column - after 3x kung binalik at puro lubrication lang ginawa. Yong part at service covered pa sya ng warranty. The SA told me that it was good that I didnt make any modifications yet sa mags at tires kasi icoconnect daw nila yon kung sakali sa sira nong steering column. Voided daw warranty agad. Kahit defective talaga yong part nila icoconsider nilang nasira yon because of mods. So its good daw talaga na either you buy and have the parts installed by them or drive your unit hard and hope all possible issues show up sa 1k or 5k PMS. May mga parts at services daw kasi na as early as 5k wala na agad waranty.
Yon sa squeking sa ilalm ng bed. Identified agad na lubrication issue. It seems common issue nga sa Strada to. I-aalign daw nila tapos lubricate. Normally daw kasi ginagawa nila greasing at 5k. Kasama sa bayad ng service buti na lang I had it checked at iwawarranty na rin nila.
Yong ripping sound naman sa break oobserbahan pa kasi they were not able to hear it during the road test. If ever wala silang makita defect, ill ask na lang that they prepare a report para may documentation ako na i complained about it in case i need it repaired in the future.
I did not report the squeking sound sa dashboard anymore. Siguro sa 5k PMS na lang.
So far I have encountered 6 minor issues sa Strada ko at actions/repairs made by the casa to date.
1) Steering wheel pulling to the left --Front wheel aligned . Under warranty
2) Off centered steering wheel -- Steering wheel manually adjusted. Under warranty.
3) Whistling sound coming from the steerig wheel-- Steering wheel column will be replaced. Under warranty
4) Squeking sound - underneath the bed -- Lubrication and alignment. Under warranty
5) Ripping sound - break related -- Issue pending. N/A
6) Squeking sound - dashboard -- Issue not yet reported. N/A.
- Aug 2009
- 181
March 20th, 2013 10:17 PM #3093dami mo ng minor issues sir, ako yung squeking sound palang sa likod ang yung sound nga din sa dashboard passenger side pero once palang nangyari so far hindi na naulit, iniisip ko nga nung narinig ko baka sa airbag maluwag ang kabit hehe, pa lubricate ko sa 1k pms next month, byahe ako this weekend para mag 1k na medyo parang lumalala eh kasi pag mga 40 to 50km/hr and nadaan ako sa medyo pangit na kalsada eh may lumalagutok talaga sa likod hindi naman yung tools kasi iba tunog nun.
- Aug 2009
- 181
March 20th, 2013 10:19 PM #3094
- Aug 2009
- 181
March 20th, 2013 10:32 PM #3095Ang bagal nga nyan sir kasi sakin sa bpi basta may quotation na ang dealer PO na agad gusto nila ang pwede daw i amend just in case magpalit ako ng dealer, pero nung sure nako sa dealer ininform ko lang si bpi ang nag PO na agad sila, bale ang nangyari sakin nag email ako ng auto loan application form then kinabukasan nag text and email si bpi na approve na daw and kuha nako quotation then email sa bpi then nag PO na agad sila tas kinabukasan ulit punta nako bpi para i submit ITR and ID xerox at paissue ng MC para sa DP at Chattel at pumirma ng ubod ng dami then kinahapunan may ATD na agad and kung hindi lang sa paglagay ng tint maiuuwi ko na agad nung hapon pero para mas pulido ang pagka ting kinabukasan ko na kinuha, siguro walang available unit yung dealer mo kaya hanap ka muna ibang dealer kasi all in all basta may unit kaya ng 2 days from application to pag uwi ng auto..
- Jun 2009
- 56
March 21st, 2013 12:13 AM #3096
- Sep 2008
- 120
March 21st, 2013 12:35 AM #3097
March 21st, 2013 01:14 AM #3098
I got mine thru Metrobank, Sir. I think it took 3 weeks before i got the unit. natagalan din sya kasi nabago raw ang quatation due to the discount given by Mitsubishi during the latter part of negotiation. Anyway, kung di naman kayo nagmamadali eh ok lang yan, but i know the excitement of waiting sometimes would give us sleepless nights.
March 21st, 2013 10:05 AM #3099
- 217
March 21st, 2013 11:21 AM #3100prob ko ngayon yung TPMS yung sa rear ko inaccurate ang reading, lalo na yung rear right, nag iindicate na flat. pero ng pag check ko matigas gulong. then punta ako gas station para magpahangin, sa indicator nila same lang yung pressure sa lahat ng gulong
pumunta ako sa casa to have it check ang aga ko pa naman, tapos 1pm pa pala pwede ipacheck pag accessories at 1pm dumadating taga winterpine. umuwi na lang muna ako, isasabay ko na lang sa PMS.
may alignment prob din ako, baka sa labas ko na lang ipagawa. nagtataka lang ako kung may ibang alignment problem, ibig sabihin ba eh di nila chinecheck sa planta ang alignment bago i release sa client
yung squeaking noise na encounter ko na din, after nung pangalawang beses nila repair di pa naman ulit bumabalik. sana nga tuloy tuloy na
i also do not know what he meant by "dim". when my since-new 2005 innova's headlight housings...
Dim Headlights Problem
