Page 261 of 501 FirstFirst ... 161211251257258259260261262263264265271311361 ... LastLast
Results 2,601 to 2,610 of 5002
    Feb 2012
    #2601
    good job on the center console cover sir! may I ask where and how much did you get it for? Appreciate the help sir.
    Quote Originally Posted by jasapix View Post
    CENTER CONSOLE (fits Strada too)
    Oct 2004
    #2602
    Quote Originally Posted by shadow3616931 View Post
    Mine is 2011 gls 4x4 M/T, 1 yr na sya so far di pa naman ako nag sisisi, medyo nang hinayang lang di ko inabot yung VGT, VGT na ata lahat ngayon even 4x4 M/T. I already have it lifted put mudtires and armory. Now I'm enjoying its 4x4 sumasama ako sa trail ng TSCP and 4x4ph, too bad i cant post picture here dont know why
    here are some pics
    http://i299.photobucket.com/albums/m..._4160724_o.jpg
    http://i299.photobucket.com/albums/m..._2635130_o.jpg
    Sir, anong size ng tires mo?
    Anong lift gamit mo (front coil/strut spacer tapos extended shackles sa rear)?
    Are you using a performance chip?
    Kumusta po ang take-off from stand-still (do you need to rev higher)?
    Planning to lift my GLX kase.
    Feb 2012
    #2603
    Question po sa mga GLX-MT owners, what RPM po kayo nagpapalit to the higher gear? When I try to shift at 2k RPM parang kulang, seems like I need to shift to the next gear at 2100 to 2200 rpm or else garalgal yung makina. Is there something wrong with our Strada?
    Apr 2010
    #2604
    I think the gear shifting depends on the acceleration of the car, the load and engine RPM. Don't rely fully on the RPM. If you travel light, you can usually change gear at lower RPM but if you have lots of load or going uphill, you will change gear on a little bit higher RPM. Observe the engine and from there decide if it's time to upshift or downshift. You don't actually need to look at your rpm...
    If you want more power on your driving you usually shift at a higher RPM. This is equivalent to how "Sports Mode" works on other vehicles. You maximize your power band before shifting. This also gives you better acceleration overall.
    However, if you want to save on gas, you shift at lower RPM.
    Going back to your question, 2100 - 2200 rpm is just fine. Diesel is good in power not acceleration. So to get better acceleration, you need more RPM. And I find my GLX just fine.
    Sorry for long response. Just thought that it might help. Otherwise, feel free to disregard.
    Feb 2006
    #2605
    I have strada glx 2010 manual
    54k milage.
    Prob ko umiilaw yung CHeck Engine Anu kaya prob into ?
    Any one experience the same?
    Apr 2010
    #2606
    Maraming possible causes sir eh. Most common yong fuel intake system, pede SCV, EGR, etc.
    Since 2010 lang yan, I suggest dalahin mo sa casa. Let them check for the actual error code.
    It should be covered by the warranty. And you should not pay for the check-up and even part replacement or cleaning.
    Because in the first place hindi mo naman binili yong auto na me check engine. So it shouldn't be there by design.
    If I am you, that's what I will do.
    Mar 2012
    #2607
    guys, i got a 2012 glsv 4x4 m/t. is there any change in fuel consumption if i change my stock tires and rim into a 20" aftermarket rim w/ 20" A/T tires? thanks.
    Feb 2006
    #2608
    Quote Originally Posted by D3nb3r View Post
    Kung same yung total diameter Sa stock I think minimal Lang yung diff
    Mar 2012
    #2609
    my stock size is 17's and going for 20's. i've heard some negative comments on fuel consumption pg lumaki na yung rim and tires.
    Feb 2006
    #2610
    http://www.1010tires.com/tiresizecalculator.asp
    Try this site might help you
2010 Mitsubishi Strada [continued 2]
