Results 4,791 to 4,800 of 5002
January 21st, 2015 09:57 PM #4791
guys ask ko lang, san kaya makakabili ng side mouldings for strada? yun same sa 4x4
plastic sana na black...
4x2 kasi sakin walang ganun T__T
- Aug 2013
- 11
January 22nd, 2015 06:06 PM #4793Kung ang unit mo ay 2011-14 GLS V model , may reset button and main stereo, maliit n butas halos sakto lang ang paper clip banda sa left side ng stereo. Pag switch on sa ignition key at lumabas na ang Mitsubishi sign pwede mo na I-reset. Ganyan non lang ginawa ng technician last time na nagcomplain ako about sa remote control not functioning at nag ok naman. Nothing to worry pagnagrereset not harmful naman sa stereo at sa monitor kasi nakita ko ang ginagawa ng technician.
- Dec 2014
- 3
January 26th, 2015 09:20 PM #4794Naku sir, sensya na at ngayon ko lang nakita to. opo malaki po, nilibre na din nila lahat ng dealer options. I put up as much down as I can and had it financed for 4 years. With the discount, parang nasa 50,000 above SRP ang babayaran ko so ok na din. If you still want the quotation, I can PM you the one they gave me.
- Dec 2014
- 3
January 26th, 2015 10:04 PM #4795
- Oct 2014
- 15
January 27th, 2015 10:10 AM #4796
Tsikot Member Rank 1
- Jul 2009
- 4,090
February 10th, 2015 10:40 AM #4798
Mga sirs na discuss na siguro before pero ask ko na rin ulit:
- if bibili ako ng mag ang rims for GLX-V na Strada na ang specs is 265/65 R17 di na ba kailangan ng lift nito? Wala na din bang rubbing?
- If ang specs naman is 265/70 R17 siya ba mas kailangan ang lift?
Hingi lang po ako ng inputs nyo. Thanks in advance
February 13th, 2015 09:43 AM #4799
*realambro07
No need lift that the same size as a stock monty tires
Still, no need lift. If compute mo yung specs na yan, around 31.6 lang. I’m using a 265/70/17 (32”) mud tires no lift on stock rims of my gls-v.
*realambro07
- Jul 2009
- 4,090
