Results 4,781 to 4,790 of 5002
December 28th, 2014 07:50 PM #4781
stock gls tires is 245/65/17 thats about 29.5" Di ko lang sure kung ang stock glx tires ngayun is nasa 205/80/16 pa rin which is pag compute mo is about 29" so halos 1" lang siguro difference nyan. divide mo yung 1", yan ang differnce ng ride height mo so halos di mo ma notice yan except na syempre yung rims since 17" yung iba and yung isa is 16"
- Jan 2014
- 15
December 30th, 2014 07:47 AM #4782May nagaalok sakin ford ranger stock tires na 265/60/18, uubra kaya yun?pwede kaya sa strada yun?
December 30th, 2014 11:01 AM #4783
Tires lang po? Or tires with rims? You cant fit a ranger size tires on a stock strada rims unless set ng tires with rims ng ranger and same holes and PCD sa strada ang ikakabit mo. Or if nka 18” aftermarket rims kana then pwede mo kabit yan. IMO sagwa din ata tingnan strada na nka ranger rims But hey, that’s just me.
- Jan 2014
- 15
December 30th, 2014 11:59 AM #4784Tires with rims, inaalala ko yung size baka masyado na syang malaki para sa stock height ng strada, hehehe
December 30th, 2014 10:24 PM #4785
- 62
December 31st, 2014 10:51 PM #4786You dont need to change all your rims and tires. You can keep your original spare. Just as long as you dont make your spare permanent.
- Oct 2014
- 15
January 7th, 2015 05:08 PM #4787For Strada 2.5 GLX 4x4 MT owners....
Steel talaga mags nung brandnew? Yung GLX 4x2 counterpart nya kasi naga alloy mags na sya.
Baka may trusted agent din kayo na pwede mairefer. Thanks
- Dec 2014
- 3
January 11th, 2015 10:09 PM #4788Opo sir steel mags lang po and the head unit is better on the 4x2. I got mine bago magpasko and was thinking of getting the 4x4 glx din dahil kulang sa budget but I ended up with the 4x2 instead. Happy na din since di naman ako mag-ooffroad. mejo napalayo din ako ng kuha because the dealer who gave me the best freebies was in manila so dun ako kumuha instead of the dealerships nearby
- Oct 2014
- 15
January 12th, 2015 09:51 AM #4789^Thanks. Malaki ba binigay na discount sayo considerring na outgoing models na yung currently available? If okay lang pwede pa-pm quotation sa inyo ng Manila dealer. Will compare sa binigay sakin ng ibang dealers. I have decided as well na 4x2 glx (gray) na lang din kukunin ko since wala na din daw ilalabas na glx 4x4 at gl na lang ang may 4x4 maybe dahil nag-uubos na lng ng unit then labas na yung bagong model....
- Jan 2015
- 5
January 20th, 2015 09:13 AM #4790Mga sir,nawala yung function nung controls sa manibela ni Strada.Bago naman battery.Halos di ko naman ginagamit. Naisip ko nung nagpakabit ako ng busina last December 20.(before naman,nung hinde pa ako nagpalagay ng new horn,ayaw gumana,pero pinalitan ko nga ng brand new battery,gumana naman although,nakita ko dati na nagkaron ng battery leak ng kaunting kaunti lang,ok naman,back to function naman)
...Then,Kahapon ko lang napansin ayaw uli gumana.Nagalaw kaya ni tech yung wirings nun?
