Results 4,681 to 4,690 of 5002
September 3rd, 2014 04:52 PM #4681
I have already inquired ATCO-Zapote, Mitsu Prime-LasPinas, El Dorado-Cubao. Wala daw silang aux fan complete assembly. Ang meron sila yun fan motor lang. Yun isang nagpakabit dito sa casa bumili at nagpakabit.
- Jul 2014
- 1
September 3rd, 2014 05:50 PM #4682
Mga boss good day. I also experienced stalled engine sa Strada when shifting to 3rd gear and also no engine response kahit tapak ko na ng husto yung throttle (often occurrence lang po).. Then naimbestigahan ko siya try ko patayin yung aircon when this happens and all of a sudden its back to normal engine response, i tried it for 2-3 times and still same effect. Tanong ko lang po kung may epekto kaya yung aircon sa issue na to? And PLEEEEASE, tell me what is EGR and SCV? im sorry pero wala po akong idea kung ano yun. I also change my iol, air and fuel filters, oil change, but still after a week nageexist pa din yung no response ng engine. If someone could insert an image of egr or scv much better po..
I hope someone could help us out of this problem before namin ipadala sa casa which may be costly.
Thank you mga sir/mam/boss!
September 3rd, 2014 09:26 PM #4683
I'm no expert but hindi kaya naka tsamba ka nang dirty fuel? na experience ko na before yan. I don/t think the aircon has anything to do with the engine stalling. About sa 3rd gear naman I had a broken 1st, 3rd and reverse gear before but hindi naman nag stall yung engine. But still your best bet is to bring your rig to a casa/serviek for OBD checks.
just to give you an overview
note: this is taken from a 4m41(non-vgt) engine but for presentation purpose only, it is almost the same as the 4d56 engine.
EGR-The exhaust gas recirculation (EGR) system lowers the nitrogen oxide (NOx) emission level.
When the air/fuel mixture combustion temperature is high, a large quantity of nitrogen oxides (NOx) is generated in the combustion chamber. Therefore, this system recirculates part of emission gas from the exhaust port of the cylinder head to the combustion chamber through the intake manifold to decrease the air/fuel mixture combustion temperature, resulting in reduction of NOx. The EGR flow rate is controlled by the EGR valve so as not to decrease the driveability.
SCV- also known as suction control valve (well its elf explanatory na )
Tsikot Member Rank 1
- Jul 2009
- 4,090
September 3rd, 2014 10:24 PM #4684
- Nov 2009
- 3,484
September 3rd, 2014 10:54 PM #4685You may start by downloading 4D56/4M40 CRDI fuel system (Denso HP3) manual here.
Denso Fuel System_Mitsubishi_triton
http://diesel-art.com/manuales/Mitsubishi_triton6Ad.PDF
SCV at section 4.2
HTH
- Mar 2014
- 30
September 4th, 2014 08:46 AM #4686Pwede ba na hindi sa casa mapapalit ng timing belt? Ang mahal kase e..my mabibilhan kaya ng timing belt for strada 2.5? Saan kaya at magkano?
- Jun 2013
- 179
September 4th, 2014 09:47 AM #4687Mga Sir good morning,
Ask ko lang ano kaya yun umiingay sa makina ko na kapag apak mo clutch nawawala, pero normal naman yun unit, hindi mahirap sa clutch or mag shift ng gear.
sa mga belt kaya yun? pasensya na po wala ako alam sa makina.
- Jun 2013
- 179
September 4th, 2014 10:37 AM #4688Update:
Tumawag po ako sa Mitsubishi, transmission daw po sira, yun nga po ba yun? 1yr and 2 months pa lang yun unit ko
September 4th, 2014 12:42 PM #4689
- Jun 2013
- 179
September 4th, 2014 12:50 PM #4690Yun para bang fan belt na kulang sa langis ang ingay, na tapakan mo nga lang clutch nawawala, kahit konting tapak mo lang sa clutch nawawala yun ingay.
Pero nagsearch ako dito meron akong nakita same na same dun sa problema ko pero sabi dun ang pinalitan daw eh clutch disc.
Sabi sa Casa nun itawag ko ibababa daw transmission
