Results 4,611 to 4,620 of 5002
- Nov 2006
- 40
August 1st, 2014 01:22 PM #4611Hi Guys,
Meron ba here know where can I see a available GLS Sport V, colors can be Red, White, Quartz Brown or Silver. Wala daw dun sa dealer na kausap ko eh. I'm not sure why wala ako makita, nagkakaubusan na ba?
BTW... I'm a member of TSCP, if you want to join, just feel free to post sa FB page or PM Chad Antonio
- Jul 2014
- 9
- Nov 2006
- 40
August 1st, 2014 01:36 PM #4613
Tsikot Member Rank 3
- Aug 2003
- 1,251
August 1st, 2014 06:21 PM #4614Yung sa akin, I had the cargo bed flooring rustproofed. I removed the plastic bedliner that comes with the vehicle, had the flooring rubberized, then put back the bedliner. Sa experience ko sa mga double cabs with bedliners, yun ang weak point nila, the space between the bedliner and the cargo box floor pwede magkaroon ng stagnant water or water build up, and it may cause the start of rust formation.
August 1st, 2014 08:58 PM #4615
Ha? Pati white wala? Sa Diamond Motors Valle Verde ako bumili.. Pag Red or Black mabilis makuha unit pero yung ibang colors, medyo matatagalan.
August 1st, 2014 11:44 PM #4616
guys question lang kung naexperience nyo rin po ba ito kung normal lang...
bale may volt meter gauge po kasi ako, tapos pansin ko pag gabi naka on headlight, aircon etc... tapos kapag traffic pag apak ko ng preno yung reading ng gauge from 13.5 to 14 bumababa ng 12.5 tapos kapag aapak na ako sa accelerator umaakyat ulit sa 13.5
is this normal po ba?
August 2nd, 2014 04:46 PM #4618
August 2nd, 2014 05:28 PM #4619
- Aug 2003
- 1,251
August 2nd, 2014 06:26 PM #4620I have done voltage tests on both the strada and montero. I have posted my findings here in tsikot a long time ago. Bottom line, bulok ang alternator ng ride natin. Mas malala pa sa montero. Ang ginawa ko, get volt reading with the engine running, no accessories. Then one by one switch on, and determine the voltage drop. Pag naka on ang headlight, yun ang pinaka malakas na drain, on idling. Sa Strada ko, it drops but holds at low 12+. Kaya pagnatraffic ako sa gabi, di ko napapansin na humihina ang headlights. Pero sa Montero at full stop traffic, humihina ang headlights at lumalakas when i rev the engine. Crosschecking with a simple multi tester, the Montero's voltage drops below 12, umabot pa ng 11.5 and going down.
Sinabihan pa ako ng Mitsu casa na normal daw yan. We did a check on 5 other Monteros and several Stradas at the casa's shop. Ganun din ang drop! Conclusion nila, that's normal. Ang sabi ko pa nga, bakit mas malakas ang bagsak sa montero, not as much sa strada. Sagot nila iba kasi sila. Sagot ko, paano sila iba, e pareho lang ang makina. Iba daw ang alternator sa montero at Strada. I pulled out the montero, at pinakalas ko ang alternator, bahala na kung ma void ang warranty. Wala naman sira sa loob.Brought both units to an outside shop, sinilip nila, pareho ang model number ng alternator!So I told the shop to swap the alternators. Bale, ang Strada alternator nasa Montero na, and the Montero alternator nasa Strada na, then continue to monitor the voltage. Ganun pa rin! Bumabagsak sa Montero. Hanggang ngayon, my strada has the montero's original alternator, and my montero has the strada's.
The only time ang voltage ng strada ko umaabot sa 11.5 pag bumusina ako. Yun nga lang kasi, ang nakakabit kasi both my montero and strada are their original horns, plus 2 sets of hellas (red color) on each car. In effect, 5 pieces of horns on each car.
Fyi, voltage drop does not happen as much on the d4d of toyota innova, or on kias with diesel engines, yung mga na test ko. Those cars hold at mid to high 12s at the lowest.
As long as the voltage holds and does not continue to drop when you add load by switching on your accessories, ok pa yan.Last edited by altec; August 2nd, 2014 at 06:29 PM.
Denali Lights, Dial Dim, & Soundbomb Review—Is It Worth The Premium? | Behind A Desk MotoDeal
Auxiliary Driving|Fog Lamps
