Results 4,451 to 4,460 of 5002
May 7th, 2014 01:34 PM #4451
May 7th, 2014 02:59 PM #4452
[QUOTE=LLOY;2347932]Opo sir, nag check engine light siya. Wala rin pong power yung makina at masyado ng umiinit. May alam po ba kayo na mabibilhan ng mas mura?
huwag mo munang patulan ang advised ng casa mag second opinion ka muna.... hehehe paging mga experts....
- Aug 2013
- 11
May 7th, 2014 03:20 PM #4453The reason of overheating is lack of water circulating in the engine due to faulty water pump. di kya dapat plitan lng muna ang water pump assy (kung eto yun tinutukoy mo sa pump assy)then patakbuhin ang makina until mag normalise ang engine at check kung back to normal na ang power. tpos request mo uli On-Board Diagnotics (OBD) scan. Because of high temperature detected by the sensor and recorded to computer not immediately ay sira ang sensor not until ma diagnose uli after mapalitan ang pump assembly. isa-isa lang ang pagawa. This is my personal idea or opinion and still up to you ang pa second opinon ka sa mga reputable mechanic shop outside.
May 7th, 2014 06:01 PM #4454
^^Yung pump assy po na sira daw sabi sa casa ay yung fuel pump sir.
Posted via Ay****
- Aug 2013
- 11
May 7th, 2014 06:18 PM #4455papalitan mo muna ng fuel pump and then try run the engine tpos ipa-scan mo uli pr mlaman talaga kung yun ibang parts ay defective tlg or maaring bumalik sa previous stage which is working. baka kc mareset o at least ma-update ang memory after replacing fuel pump and run the engine.
May 7th, 2014 07:08 PM #4456
^^Yun po ang gagawin namin bukas sir. Titignan muna namin ang fuel pump kung talagang sirang sira siya. Sayang naman yung gagastusin sir ang mahal kase.
Posted via Ay****
May 11th, 2014 03:24 PM #4457
may solution na po ba tayo sa squeaking leaf spring? thanks... 3 times ko na dinala sa casa eh....
Posted via Tsikot Mobile App
- Jun 2013
- 179
May 12th, 2014 09:48 PM #4459
Good evening Everyone!
mga sir baka meron po kayong kilala nagbebenta ng carryboy canopy especially yun G3 model kasi yun talaga type namin.
kahit iimport pa basta sigurado and 30-45 days lang...
kanina kasi galing ako sa carryboy banawe WALA daw kasiguraduhan kung KELAN dadating pero MERON daw... nakakalungkot lang kasi eh March pa ako nag aantay till now wala parin...
badly need ko lang nun cover this coming June-July...
pahelp sana guys..
May 14th, 2014 11:59 AM #4460
thank you its good naka timing chain pala.
