Results 4,391 to 4,400 of 5002
March 21st, 2014 09:49 PM #4391
By "stop" you mean naka idle ang engine mo? Pag naka idle po ba yung engine ay na notice nyo ba ang rpm an tumataas at bumababa? Better bring you rig to a certified aircon specialist. Dami din mga causes yan but I don't think adding an auxiliary fan will solve the problem that you have. Dahil kahit mag install ka nang fan and marumi yung cooler condenser hindi pa rin mag improve yung aircon mo. Ma notice mo rin pag medyo kulang na ang freon is medyo mag mga frosting kang makikita sa piping nang aircon. If medyo DIY ka, masisilip mo rin yung pipings nang evaporator just below the steering, just above the accelerator pedal medyo tatangalin mo lang yung mga panels na naka screw and grommet clips.
- Oct 2008
- 64
March 22nd, 2014 02:11 AM #4392
- Dec 2011
- 16
March 22nd, 2014 09:25 AM #4393
- Dec 2011
- 16
March 22nd, 2014 09:29 AM #4394
Sir stop ko means naka idle. nawawala lamig kapag matagal naka idle ng tanghali. steady lang naman yung idling ko. kapag ni rev ko lalamig nanaman, Hindi ko kung kapag ni rev ko pa lumalakas hangin kaya lalamig ulit.
Before ako bili ng auxiliary fan baka hindi rin ma solve problem. sa Gabi walang problema malamig pa rin aircon. kapag maiinit lang panahon talaga.
- Apr 2010
- 131
March 22nd, 2014 11:00 AM #4395check mo muna sir AC belt, baka luwag lang. Nothing to lose ka nman sa aux fan. even if nde yon ang problem mo, malaking tulong yon. for me, i just go the cheaper option, 500 pesos aux fan sa mga autoshop. kaya lang kelangan mo i tweak at gawan ng bracket.
Posted via Tsikot Mobile App
March 22nd, 2014 03:30 PM #4396
So bumubuga pa rin yung fan blower kahit na when you said it stopped. Have you check na yung setting nang thermostat or the bulb of the thermostat? pwede din na marumi na masyado yung evaporator mo. Gaano na po ka tagal since last service/cleaning nang aircon nyo?
Buying an auxiliary fan is ok since makakadagdag nang cooling effect yan sa freon pag daan sa condenser but if nasa ayos ang system nang aircon mo, you wont be needing that. Di hamak na mas malaki yung cabin area na pinapalamig sa Montero compare sa strada kaya it needs an auxiliary fan. But still, walang masama in buying/installing the aux. fan if may extra cash ka pa.
- Dec 2011
- 16
March 26th, 2014 12:37 AM #4398
- Mar 2014
- 2
March 27th, 2014 04:20 PM #4399Mga sir Tanong ko lang if may na experience na kayong squeking sound sa manibela pag lumiliko. Less than 2k palang strada ni misis may gnun na kse
- Jan 2014
- 15
March 28th, 2014 09:51 PM #4400hi! new owner here. strada 2014 glx-v automatic. ask ko lang po tungkol sa auto lock. kasi pag nilock ko nag bliblink yung blue light so tingin ko di sya naka valet mode (correct me if im wrong). trinatry ko kasi na iclose yung door tapos hintayin na maglock ng kusa kaso di sya naglolock. ganun po ba talaga or may kelangan pa akong gawin? tapos yung sa dash, possible ba na makita ko yung fc sa monitor? may kelangan pang gawin or idagdag?thanks!
Traffic!
