Results 4,361 to 4,370 of 5002
March 13th, 2014 02:00 AM #4362
pag na lift tayo iiba talaga ang geometry nang suspension natin. dapat ingatan natin yung cv joint at yung sa mga naka manual tranny naman delikado din yung center bearing pag nag lift above 2". IMO, pag di ka rin lang naman pumupunta sa mga heavy trailing and ground clearance lang ang habol, then lift block and spacer ay oks na tapos samahan mo pa nang 32" tires so mga more or less 5" na itataas nang ground clearance nun. But if you have deep pocket and budget is not an issue then full aftermarket suspension kit na lang pa install mo
some info from aussie triton forums:
- Jun 2013
- 179
March 13th, 2014 07:37 AM #4363
March 13th, 2014 09:04 AM #4364
Medyo subjective ata yung "kung anong bagay" na sentence sir. Meaning kung anong bagay tingnan. A rugged look might not be good looking for others but then a low profile look might look baduy to others. Depende po ata yan. The most important is gusto mo yung ginawa mo sa rig mo and alam mo yung feeling na pag baba mo nang sasakyan mo and habang papalayo ka ay napapalingon ka sa rig mo and smile. That means your satisfied with what you did Test fit mo na lang sa shop sir, in that case maka trial and error ka. and also IMO a lifted rig with a low profile set-up would not look good for me, hehehe. but that's just me. We just have to remember not to sacrifice safety for porma dahil most if not all of us here ay hindi naman sumasali sa trails and car shows.
- Sep 2010
- 21
- Jun 2013
- 179
March 13th, 2014 10:51 AM #4366
March 13th, 2014 12:38 PM #4367
check mo yung rig ni sir guilf https://www.facebook.com/guilf.nadunop/photos_albums naka 285/50/20 yan, -12offset nang rim. angas nang porma nyan. Plan ko similar din na set up sa kanya but ipon muna for the lift, rim and tires, bago lang kasi ako nag pa install nang HID projector.
March 13th, 2014 01:12 PM #4368
makisabad na nga po...
pag ang ipapalit ko pong tires ay 270/70/17, kailangan pa ba ng lift?
- Jun 2013
- 179
March 13th, 2014 02:04 PM #4369
- Jun 2013
- 179
March 13th, 2014 02:05 PM #4370
Daming issue ng SU7:grin:
Xiaomi E-Car
