Results 4,301 to 4,310 of 5002
February 13th, 2014 08:30 AM #4302
- Jan 2014
- 37
February 17th, 2014 10:00 PM #4303killer_eyes and crv99nr tnx sa mga reply nyo...so excited to drive my gls v 4x4..waiting na lang ako sa unit,naka down na ng 20t for reservation...
- Feb 2014
- 3
February 17th, 2014 10:18 PM #4304Gud pm sirs,
My 3.2 2009 AT Strada have this 'garalgal' everytime my aircon is on - parang krag-krog ang tunog. Sira kaya? Wala naman nababawas sa lamig, pati pasahero ko naririnig nila. Is this normal for our trucks? Never had it before.
Where's the best shop for this kind of problem? Maraming salamat!
- Nov 2009
- 3,484
February 17th, 2014 10:50 PM #4305
February 18th, 2014 09:39 AM #4306
San mo naririnig yung garalgal? is it inside the cabin lang? May time din minsan after mag service nang A/C sa casa that they mis-aligned the latches and yung mga mechanical interlocks pag balik nila kaya nakakarinig tayo nang mga lagutok when the aircon is running. Meron din instances when you install a cabin filter na nag sag yung filter nang konti and medyo tumatama yung center nang fan blower dun sa naka sag na part nang cabin filter. That is base on my experience lang naman. For initial inspection pwede mo naman ma visual check yung mga spaces and parts in and around the A/C if meron abnormality.
- Feb 2014
- 3
February 18th, 2014 06:51 PM #4307Sa loob ng cabin. Audible din sa labas. Erratic eh, minsan meron pero mahina, minsan ang lakas parang sira ang ilalim- mukang tunog taksi na lumalagutok dahil walang maintenance. Hopefully this weekend pa checkup ko.
Any reco AC shops within Makati?
- May 2010
- 78
February 19th, 2014 02:56 PM #4308hi sirs, I have a concern with my 2008 strada. I've done some back reading pero no clear answer for me, even with Monty threads.
My strada 80k km under its belt. during last LTO registration, 'pasang awa' lang siya sa emission test. this is weird considering that I use Petron Turbo Diesel, Motul CRDI Sipecific 5W40 fully synthetic engine oil, plus all the filters were just replaced during the check up (oil, engine, air). ok ang FC at 11-12 km/l.
when i called Mitsu, sabi baka EGR ang problema. when i researched on EGR, minsan pala cause ng problema ay ang engine oil. dapat pala at leasst CI-4 yung rating para sa cars with EGR. concerned ako bigla coz i've been using Motul since the 70k km mark. Ok naman specs ng Motul except that SL yung API rating nung nilabas dito, which is not good enough for the EGR. Meron yatang motul na SN rating kaso yung nasa ACE hardware SL lang.
Ipapasok ko lang sa Mitsu ulet to have my EGR checked. baka kse linis lang ok na. But if ever malaki problema sa EGR, hindi kaya Motul CRDI specific yung dahilan? should i consider other Fully Synthetic oils such as yung Mobil Delvac 1 na CI-4 ang rating.
Dami rin kse akong nababasa na ok naman sa Strada and Monty users ang Motul eh, so baka at 80k km, due lang talaga for cleaning ang EGR ko.
thanks in advance, mga sirs!
sources:
ACEA Classification - Lukoil
Car Bibles : The Engine Oil Bible
- Apr 2010
- 131
February 19th, 2014 03:16 PM #4309*Avaris008
At that km and if you haven't clean yet your intake manifold and egr assembly, I strongly suggest you go ahead and ask your dealer to clean them... And highly suggest to clean both... After which, you can blank your EGR to avoid similar situation (clogged intake manifold and EGR) in the future... PM me if you need blank plate.
February 20th, 2014 12:00 AM #4310
good pm
Guys ano po kaya magandang kunin tires sa dalawang ito..
Yokohama Geolandar ATS
Mickey thompson AT
parehas kasi silang tahimik "daw" sa highway and maganda gamitin...
Latest mileage:
