Results 4,121 to 4,130 of 5002
December 3rd, 2013 10:32 AM #4121
- May 2009
- 406
December 3rd, 2013 01:05 PM #4122
- 217
December 3rd, 2013 02:45 PM #4123may possibility din siguro kasi matanda na ang design ng current strada. pero ang disadvantage if new models, lalo na if new engine at design, may mga flaws pa yan sa unang labas.
unang labas ng mga crdi engines dito sa atin daming naging problema, mga 2010 na lang ata nawala. so pag new models risk sa flaws. kahit yung ranger ngayon may mga flaws na inaayos pa. wala ka ding makukuhang actual review sa new model. aasa ka lang sa mga magazine/youtube etc. pero di sya yung daily driven. mga test drive lang
December 5th, 2013 10:38 PM #4124
pano ba tanggaling ang periodic maintenance warning sa HU ng 2013 strada? ano po ang code? pano po iinput? thanks...
December 7th, 2013 09:10 AM #4125
- May 2012
- 105
December 7th, 2013 10:40 AM #4126
December 7th, 2013 10:59 AM #4127
Pwedeng pwede Sir. Ginawa ko na mag pa reset sa ibang Casa.
Malapit lang kasi ako sa Casa kaya pati pagpa pa spray ng rust sa ilalim sa may leaf spring pinagagawa ko sa kanila . Nagpaturo na rin ako kung papano, so bumili na ako ng sariling pang spray. Then pag nag ha hung ang USB function sa kanila ko rin pina ri reset dati, ngayon alam ko na rin kung papano.
December 8th, 2013 12:29 AM #4129
Hi guys, just want to share this. Thanks by the way to zix8888 for giving me advice on what to look out for when bringing in the car for the event described below.
Three days ago, I had DMC in Valle Verde look into the check engine light (CEL) indicator that lit up in the instrument panel. They only managed to make preliminary assessment and cleared the visual alarm. They did pinpoint the source of the alarm to "fuel exchange filter failed" which I later knew to be trouble code P1276 (TC P1276) using their diagnostic software on a laptop which was connected to the data terminal in the car. They asked me to bring back the car if the CEL lights up again so they can change the fuel filter. Indeed, yesterday the CEL lit up again.
I'm much nearer to Mitsubishi Carworld Malolos so I brought the car to them today, instead. Carworld used the findings of DMC and they did the following procedures:
1. took sample of diesel from the filter. they observed presence of water
2. they pulled down the fuel tank, with all 70+ liters of Petron diesel in it.
3. drained the tank
Here is a photo of my fuel tank being drained of water-contaminated diesel. Frankly I can't tell the difference. but then again, they are the experts.
4. check for rust outside and inside tank (none seen)
5. check fuel "passages" from the fuel fill cap to the sensors for rust and contamination (none seen)
6. bought new 20 liters of diesel from Caltex in a clean container and refilled tank
7. only then did they replace the fuel filter
8. hooked up the laptop and software. Cleared P1276 and run diagnostics again. No troubles found.
9. computer recalibrated the injectors and all the other stuff automatically through software
A snapshot of the the laptop's screen while performing diagnostics.
10. road test.
All in all, I think Carworld Malolos did a good job in solving the problem by addressing the root cause and not simply changing the fuel filter. That said, I hope that's all there was to it and no other trouble will surface for the time being. fuel filter cost (P1,134.00) including labor, misc and vat totaled P2635. Madumi na din actually yung lumang filter. May nakasabay akong Montero, binaba din fuel tank at kasing dumi din yung fuel filter. I didn't ask but I think, nag CEL alarm din yung kotse nya.
I also observed there were a bit of rust on a few spots underside of the car. So my next job for it would be full rustproffing. In the meantime, sa Caltex diesel naman muna ako.Last edited by CtrlAltDel; December 8th, 2013 at 12:35 AM.
- Apr 2010
- 131
December 9th, 2013 07:15 PM #4130I experienced the same CEL code. Probably 3 times. Tried to clear it couple of times as I didn't have the fuel filter replacement that time because I already knew from the code that it is most likely the fuel filter. I checked fuel filter cartridge from El Dorado, it cost Php 2.2k that time. So I tried to look for a better replacement (hopefully) and end up with Baldwin BF7535 for ~half the price of the OEM. So far no code whatsoever. I didn't bother to pull down my tank. I believed that the built-in fuel-water separator in the filter worked for me. That it didn't throw related code but rather fuel pressure related code which could likely be due to clogged filter. (SCV could affect pressure delivery too but no code related to SCV, hence, tackled the closest possible failure point first.
The gist, scan your CEL and if it is P1276, try fuel filter replacement first... (Enough)Water in the fuel filter will throw a different warning light in the dash.
Just sharing. HTH.
Ride is 2010 GLX
Discover the ultimate in relaxed romance with the best casual dating platform! Authentic Ladies ...
Exemplary Сasual Dating - Verified Damsels
