Results 3,911 to 3,920 of 5002
September 19th, 2013 01:20 PM #3911
ah ok sir. thanks for sharing the pics. And your right medyo mahirap nga na maging watertight yan since iba ang movement nang main cabin sa cargo bed natin pag tumatakbo. Well at least if di naman ganun ka lakas ang leak nag cool air dun sa seal ok lang yun, lalo na sa mga extra passengers na na sa cargo bed
Ito ang reply nila sir.
Our Customer Care Team has coordinated your concern with our Service Department and your servicing dealer, Evolander Motor Corporation (EMC). Based on their technical findings, the headlight usually has moisture inside its body. As the headlight is turned on, the temperature of the light bulb with its surrounding parts will increase and the water around those parts will evaporate. Thus, the absolute humidity inside the headlight goes up. If the front surface of the headlight (i.e. front lens) is cooled down by rain shower, car wash, or even cold wind, the temperature of the lens becomes lower than dew point of the air inside the headlamp body. Under this condition, dew concentration will occur on the headlight lens inner surface. Please understand that this is a normal phenomenon called "Condensation" and is not a product defect.
Humihingi ako ng spec sheet ng fog lamps pero wala daw sila. I cant believe na wala sila nito kasi requirement ito ng product at dito nakalagay yung details ng fog lamps. salamat
Edit: sabi nila dyan na "based on their technical findings" meaning yung nag sulat nang report, either servicing department or evolander. If they reported a minor moisture lang then the management will most likely deny your claim.
- Oct 2005
- 16
September 19th, 2013 01:38 PM #3912san kayo naka tira banda sir? muzon lang ako. oo nga, hassle tlga itong casa na ito, lilipat nako sa may valle verde, I've heard na ok dito. I told them i wawaranty claim din nila ito sa OEM which is denso kaya paper work lng ang dagdag na trabaho nila dito at walang cost. I do not believe that they should be dumb/ playing dumb kasi kung hindi nila alam ang kanilang ginagawa dapat e lumipat na sila ng trabahong para sa kanilang skill set. they are being payed for something they are not capable. I believe in the Mitsu brand sayang lang at nasisira ito ng mga ganitong tao.
September 19th, 2013 01:57 PM #3913
naku ang layo ko sir. nasa Mindanao po ako. Dyan ko lang kimuha sa Manila yung unit ko. Approachable naman mga taga Mitsu casa dito sa amin. Lipat nlang nga siguro kayo sir nang casa.
About the dumb or playing dumb thing, that is base on my experience. Di ako mag bibitaw nang salitang ganun if they are not like that.
For example: last time I told my wife to buy a cabin filter since our rig doesn't have one when it came out of the dealer. Then I told my wife na isabay na ang pag palit nang cabin filter sa routine PMS (I'm an OFW kaya wala ako sa pinas). Nung mag PMS na and my wife told them to install the filter, ang sagot is, we'll see na lang maam dahil di pa kmi nka kabit nyan sa strada. monty lang daw. I said,to my self Holy sh** pareho lang ang cabin filter nang strada at monty. then they told my wife na sabay nalng daw sa next PMS pag nag linis nang aircon. so antayin muna dumumi bago lagyan nang filter. Kaya I hope you see my point.
- Apr 2010
- 131
September 19th, 2013 02:00 PM #3914Sir mas maganda ma picturan mo foglight. then compare left and right. mmpc kasi nagrerely lang yan sa report ng warranty officer ng casa. tsaka subukan mo dalhin sa ibang casa. dvv is a good casa interms if warranty claim as far as i read. good luck.
- Oct 2005
- 16
September 19th, 2013 02:05 PM #3915oo nga sir. sabi ko sa EMC certified sila ng MMPC kaya dapat trabahong certified ang gawin nila. kausap ko na yung manager nila pero hindi rin sya makapag decide.
"As the headlight is turned on, the temperature of the light bulb with its surrounding parts will increase and the water around those parts will evaporate." sinabi ko na ngang 2 to 3 days bago mawala kahit ginagamit yung fog lamp pero hindi parin nya magets na hindi nga nag evaporate. Well lessoned learned ito na hindi porke malapit walang hassle.
- 217
September 20th, 2013 09:12 AM #3916di talaga normal yan kung ganun katagal.
do you have a regular SA sa casa? usually they can help lalo na kung good terms kayo. pwede nya lakarin na ma claim mo.
sa crosswind nun sinabihan ako agad ng barkada ko from plant na may issue ang headlight ng crosswind. so kung matapat daw na mag moist, wag daw ako papayag na i reseal, papalitan ko daw at papalitan din naman ng planta.
siguro naman pareho lang situation nun.
usually pag ganyan may prob sa seal ng headlight, yung aftermarket fog ko ako na lang nag reseal. kaso ibang usapan yan kasi may warranty pa dapat yan
September 21st, 2013 11:31 AM #3917
anyone looking for Racechip Pro 2? i'm selling my 1 month used RCP2, complete with box and manual, PM me if interested...TIA
- Jul 2013
- 193
September 21st, 2013 09:23 PM #3919
September 21st, 2013 09:38 PM #3920
mga sir kapag po ba pinalitan ko mags and tires ko maVOID po warranty?
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
