Results 3,901 to 3,910 of 5002
September 18th, 2013 02:39 PM #3901
Almost the same as my question before... Sayang yung 16" mags so para mas malapad at konting taas kesa stock tire na 205/80-R16 pwede pamalit yung 245/70-R16. Ang pagkakaiba nila:
Width 245-205=40mm
Thickness (245*0.7)-(205*0.8)=171.5-166.4=5.1mm
Or additional 10.2mm sa diameter
I already saw 245s fitted on 16" stock rims on a strada here in Pasig city. Sinulat ko talaga yung size ng makita ko. Astig sya tingnan sa unmodified glx body. Itong goma ipapalit ko once napudpod na stock tires.Last edited by CtrlAltDel; September 18th, 2013 at 02:46 PM.
- Apr 2008
- 6,237
September 18th, 2013 03:11 PM #3902
- Oct 2005
- 16
September 18th, 2013 07:36 PM #3903Hello po baka may naka experience po kayong ganito? yung unit ko po is 2012 strada na may 16k mileage ang issue ko po is yung driver side na fog lamp nung sasakyan ay nag momoist covering yung buong glass at 2 to 3 days sya bago mawala even with use of fog lamp light. para saakin at sa mga nakausap ko hindi po ito normal. yung sa passenger side na fog lamp ay hindi naman nag moist kahit kelan. Tumawag narin po ako sa MMPC at yung technical na taong nakausap ko ay sinabing hindi daw normal yung ganito at product defect ito. Nung nag claim naman ako sa EMC sabi nila dineny daw ng MMPC yung warranty claim nila. Meron po bang naka ranas ng ganito? sana po may makatulong. salamat
September 18th, 2013 10:57 PM #3904
Bro I suggest you get your warranty booklet and owner's manual. Basahin mo doon ang coverage ng warranty. Minsan ko lang binasa ang booklet madali pa kaya hindi din ako sigurado kung covered ang mga ilaw. Sakaling covered, then you can formalize your complaint in a letter citing the coverage. Kung hindi covered, you can still write your complaint stating your disappointment for a defective product.
Good luck! By the way ano yung EMC?
- Oct 2005
- 16
September 18th, 2013 11:31 PM #3905Maraming salamat bossing pero covered sya. 3 yrs ang warranty nila or 100k m kaso ang pagkakaintindi ng mga tao from MMPC and EMC ang magulo. Would you agree na dapat magkaroon ng tubig sa fog lamp at headlight mo? This is defenitely not normal but they are saying it is normal.
September 18th, 2013 11:34 PM #3906
Ang nasa manual, it is normal na magka moisture sa headlights / foglamps.
Ang hindi normal e mag moist tapos hindi nawawala after a few days. Or kung mawala man, e may water spots sa loob. If you can, try to see kung tama ang pagka mount ng bulbs sa fogs mo. Nasa manual din ang instructions kung pano gawin yun.
Please read the manual.
September 19th, 2013 12:25 AM #3907
September 19th, 2013 04:14 AM #3908
ah, ganun ba sir. so hindi parin pala water tight yung seal na ginamit nila. may pics po ba kayo nang seal na ginamit?
- Apr 2008
- 6,237
September 19th, 2013 09:49 AM #3909
- Oct 2005
- 16
September 19th, 2013 01:06 PM #3910Ito ang reply nila sir.
Our Customer Care Team has coordinated your concern with our Service Department and your servicing dealer, Evolander Motor Corporation (EMC). Based on their technical findings, the headlight usually has moisture inside its body. As the headlight is turned on, the temperature of the light bulb with its surrounding parts will increase and the water around those parts will evaporate. Thus, the absolute humidity inside the headlight goes up. If the front surface of the headlight (i.e. front lens) is cooled down by rain shower, car wash, or even cold wind, the temperature of the lens becomes lower than dew point of the air inside the headlamp body. Under this condition, dew concentration will occur on the headlight lens inner surface. Please understand that this is a normal phenomenon called "Condensation" and is not a product defect.
Humihingi ako ng spec sheet ng fog lamps pero wala daw sila. I cant believe na wala sila nito kasi requirement ito ng product at dito nakalagay yung details ng fog lamps. Tinatanong ko din yung breather kung single or dual ang function nya hindi rin nila alarm. Sa tingin ko its more on the technical knowledge ng taga MMPC at sa EMC. kasi hindi nga nila alam yung spec sheet. Sabi ko din pari ang fog lamps, left and right pero right lang ang nag kaka ganito, sabi ko din sa kanila na hindi dapat naghahala ang water at electricity. I think I had enough sa kasang ito at lilipat nako sa iba. salamat
just seen a 10th gen cross 200,000 miles on reddit. is this a unicorn or has the cvt been proven...
All New 2016 Civic
