Results 3,621 to 3,630 of 5002
- Jul 2013
- 193
August 5th, 2013 01:55 AM #3621Hindi po kaya mapadali ang buhay ni 4d56 kapag pinagtrabaho sya beyond sa kaya nya itrabaho? E2 yung argument sa kin ng friend ko eh.. san nga daw ba kukunin yung power? Sa chip o sa block? Bakit di pa ito inilagay ng mga manufacturer?
August 5th, 2013 02:45 AM #3622
yes, bakit nga ba di pa nilagay ng mga manufacturers yung mga performance parts? well clearly your friend bought his car just to carry him from point A to B. ask your friend also this simple question: is he satisfied of the tints that the manufacturer installed on his ride? or he wishes he has a vkool tints on his car for better heat rejection and uv protection. if the manufacturer put all performance parts on our rigs engine then i think most of us will complain na naman bakit ang mahal ng price nung car. also some of us dont like the stock look of our rigs tires that's why we change it to either m/t's or bigger/wider rims. you think ganun pa rin ba ang price nung rig/car natin if have a 295/65/20 nitto trail grappler w/ 20" rim and 7" suspension lift?
performance chip is like a budget meal if you want to tweak some imperfections on you engine, instead of installing bigger intercooler, turbos, injectors and etc. the chip only fine tunes your system and our car's ecu can even override the chips signal if our ecu doesnt like what it reads. i'm not an expert on engine mods, i just understand why we do engine, suspension and aesthetic mods
i attached a dyno run result w/ and w/out the chip by berima diesel.
- 217
August 5th, 2013 09:42 AM #3623sir kung may prob ka sa alignment pa note mo lang sa SA para marecord, pero dapat talaga i align na nila yan
sa case ko 4K+ nag reklamo ako may kabig, then per schedule lang daw alignment nila, 15K pms na ako nakapag pa align lagi kasing ang hirap pa sched. di naman nila chinarge yung alignment since sabi ko may record ako. pero yung wheel balance sa labas ako nag pa balance
August 5th, 2013 01:18 PM #3624
- Jun 2013
- 179
August 5th, 2013 01:48 PM #3625
August 5th, 2013 02:16 PM #3626
A week ago , Diamond service center replaced the Inhibitor switch ng transmission ko, what I've observed is that sometime engine won't start if the stick is on P position, kailangan galaw galawin up to N, then that's the time will start, ibabalik ko sa casa parang na offset siya, also minor kalampag nangagaling sa right engine area, Im still at the guessing stance kung saan nangagaling
August 5th, 2013 02:43 PM #3627
August 5th, 2013 03:00 PM #3628
Tsikot Member Rank 1
- Jul 2009
- 4,090
August 5th, 2013 03:28 PM #3629
Monk-owned R53
