Results 2,781 to 2,790 of 5002
Tsikot Member Rank 1
- Jul 2009
- 4,090
July 24th, 2012 02:55 PM #2781
- Jul 2010
- 25
July 24th, 2012 10:14 PM #2782
July 25th, 2012 03:02 PM #2783
Hi,
Last saturday ginawa (cleaning maintenance Strada 3.2 A/T) yung EGR & other parts connected sa system, including the SCV, the battery was disconnected. Matapos ng cleaning it was boxed up and had to revs high (up to 4000 rev) to displace the carbon deposit. Noted that time setting can't be adjust, fuel not in conformity w/ the gauge dahil the display in the monitor is still full but the needle gauge is 3/4, Im planning to disconnect the battery again hoping it will settle the problem, any idea mga sir baka na encounter na ninyo ang similar problem & able to rectify, pa share naman.
Thanks-RTS
July 26th, 2012 10:46 AM #2784
bro zix888, did you make the white cover o oem part na yan? Iba kasi sa rig ko . I needed to cut out the front part para ma pasok yung filter tapos I just sealed it with silicone. Not the best way kaya I was thinking of making the same cover.
pic from filter supplier.
*eilynn15 it's a 30min job kasi yung supplier ng filter emailed me detailed pics with instructions.
*J_AIRBUS3XX Got tired of cleaning aircon vents. My rig goes through very fine dust weekly na kahit naka recirc yung aircon pasok pa rin kaya I opted to install the filter. I dont have warranty since week three kaya ok lang . I would suggest you call your casa to confirm regarding your warranty.Last edited by jubs00; July 26th, 2012 at 10:54 AM.
July 26th, 2012 10:52 AM #2785
July 26th, 2012 12:10 PM #2786
- Jul 2009
- 4,090
July 26th, 2012 03:43 PM #2787the one that you installed utilizes the plastic part that was cut out para gamitin pang cover. the one that i installed, you need to cut the whole thing out, the filter comes with that cover frame that is mounted thru the oem screw opening.
regarding naman sa scv, cel will follow after cleaning, you need to do a learning procedure which is done using under the laptop. just have the egr cleaned, just wait for the scv to wear out normally.
July 27th, 2012 02:25 PM #2788
July 27th, 2012 04:38 PM #2789
July 27th, 2012 04:43 PM #2790
Mazda 3 is incredibly tempting, unfortunately the hybrid is not included in the coding exemption...
All New Toyota Corolla Cross
