Results 2,701 to 2,710 of 5002
- Nov 2006
- 338
May 26th, 2012 10:23 PM #2701Anyone tried blocking the EGR with block plate?
so no need to clean egr and avoid carbon build up?
thanks
May 27th, 2012 03:35 PM #2702
I'd like also to do this but I've read on other sites na mixed yung results nila kaya medyo nag alanganin din ako. Some went 30-60,000k's without any CEL's yung iban naman 1000k pa lang after installing nag limp mode na. I'm guessing some owners here did this mod already so let's just wait for other inputs. But for me I'd rather clean my egr myself or have my casa do it.
May 27th, 2012 04:29 PM #2703
I am also interested in this modification for a permanent and cost effective preventive maintenance. I think the blocking plate is installed before the corrugated pipe (di ko alam ang tawag dun; baka intake manifold) that connects to the EGR assembly. And after or before blocking, an OBD2 computer is used to cancel or disable the EGR diagnostic program para hindi ma-detect ang blocking at hindi mag-activate ng limp mode. Until I am sure of the process, ipalinis ko nalang ang EGR assembly every 20K kms sa labas para P350 lang ang labor compared sa case na almost P800, excluding pa other pipes that need to be cleaned. Installing an oil catch can/tank does lessen the carbon sludge buid-up sa EGR as well as a alcohol injection system (water lang ilagay para ma-burn lang ng carbon build-up). Yung oil catch can/tank mura lang, madali lang i-DIY at i-maintain pero medyo magastos yung alcohol injection system tapos wala akong planong maglagay ng alcohol/methanol (para siguradong tatagal ang makina).
May 29th, 2012 08:48 AM #2704
And if you do blank the EGR, you'll just have carbon build up somewhere else. Intresado din ako sa AI to avoid the carbon build up and for the added hp it will give me. It will cost a good amount of money but the benefits will even it out.
My suggestion is, just blip your throttle once in a while to clear those carbon deposits.
- Nov 2011
- 18
June 1st, 2012 03:55 AM #2705mga bossing, may itatanong lang sana ako..i drive a 2011 GLX-V at recently parang sinisinok yung makina ko kpag nka-menor ako..mga 1300-1500rpm..taas baba yung rpm ko..nwawala nmn xa kpag diniinan mo pa yung rev..basta lumampas xa dun sa 1500rpm, ok na..na-eexperience ko xa malimit kpag city driving na mdaming ptigil tigil.. di cguro sa engine ung problema kc kpag nmn nka-idle xa eh walang problema. last month na-experience ko din na parang bumababad sa 2nd gear..antagal bago mgshift..halos hagok na ung mkina..pero nung dinala ko sa casa, at tnest-drive eh nwala bigla.. anu kaya problema mga boss. halos 6 mos. plang sakin si "erap", 5k PMS nya din this week, sana msagot nyo ako pra yun ang maulit ko sa casa. thanks!
- Nov 2011
- 18
June 2nd, 2012 03:33 AM #2707
- Jul 2010
- 25
June 3rd, 2012 11:20 PM #2708
- Jul 2010
- 25
June 10th, 2012 09:40 PM #2709
- May 2008
- 12
June 11th, 2012 10:43 PM #2710Mga sir,
new 2011 GLX strada owner here. Mag 3 weeks old na strada ko sa akin pero 11mos old na siya(2nd hand ko nakuha from a friend). May question po ako about sa sound pag dumadaan ako sa humps diagonally. Sanay kasi ako sa car kaya lowered style lagi yung entry ko sa mga humps. May nanonotice ako na sound mapa left or right pag nag huhumps ako. Hindi siya yung parang cracking sound na tuloy tuloy. More of isang "tok" lang siya everytime na may humps ako dadaanan. Although nung kinuha ko siya wala namang ganyan. This week ko lang napapansin. Tinry ko i shake yung strada ko pero hindi lumalabas yung tunog. More on pag may humps lang tlga and left wheel first/right wheel first. Thank you po in advance hintayin ko na lang yung mga reply para bukas ng umaga makakapila na ako sa ka isa isang Mitsu sa CdO.
*Sir Doy, thank you for recommending Michelin and Ajcarhub dito sa CdO. Nakahanap na ako ng stock replacement sa nabasag ko na reflector. 700 lang bili ko
Suzuki JIMNY [merged threads]
