Results 2,481 to 2,490 of 5002
- Sep 2006
- 30
February 21st, 2012 06:18 AM #2481Hi guys
while driving last sunday,biglang umilaw yung ABS warning light sa panel so i asked my companion to read the manual we found that we need to stop driving and stop the engine for a few minutes then drive again . nawala naman nga yung warning light, nakalagay sa manual pag nawala yung light then it is normal. my question is, how normal is this on our strada? wala kase ito sa mga nabasa ko when I backread before i bought it , btw my odo is still on 800km+ ,should i wait to have it checked on my 1000kms pms or bring it right away na sa casa?
February 21st, 2012 04:51 PM #2482
i believe sa mga 2012 models pa lang nagumpisa maging ABS equipped yung mga strada (or baka naman nalilito lang ako, pero alam ko even yung mga GLSs dati di pa).
baka kaya siguro when you backread walang ABS-related concerns.
kung di rin naman going out of the way, then try swinging-by na sa casa.
or you can call the service dept and ask about the concern, in which i imagine na sasabihin nila dalhin niyo sa kanila para ma-asses ng mabuti.
but at any rate, at least that would have you asked someone from the casa na talaga.
--292. Marco
- Nov 2011
- 3
February 22nd, 2012 03:51 PM #2483manga pare normal ba na mag automatic on ang radio nang mit. strada gls sport v 2012
after few second na ma start, kahit e manual off ko ang radio pag start ko uli mag auto
on and radio.
- Sep 2011
- 24
February 22nd, 2012 11:23 PM #2484mga sir good pm po.. new strada owner po got our unit last week ng jan 2012.. glx-v at po nasa 1300 na ang milage ko, at naka 5 balik nako ng warranty claim.. sa winterpine kasi ung steering remote control ko e di gumagana.. inayos na nila sa pamamagitan ng pagpalit ng head unit ko na alpine kasi daw sira yung IR nung face ng headunit ko, tapos ngayon delayed ang responce ng dteering audio remote ko haaaayyyyy, tapos 3 times na nagstock up ang driver side power window ko, dinala ko sa casa meron lng daw loose na socket pero ngyn ok na haaaaaayyyyyyyyyyyy
tapos ngayon parang meron ako nareirinig n squeeking sound sa rear suspension ko haaaaaaayyyyyyyy
any of you guys experienced this?
February 23rd, 2012 06:59 PM #2485
If your acceleration is not affected (constricted)nothing to worry, sa akin madalas mangyari ang ganyan ,at first i was worried like you bring ka agad sa nearest mits shop, but now sanay na ako, mawawal pag nag tagal tagal nandyan naman, unless you change your SCV w/ suitable spec masanay ka na dyan.
RTS
- Sep 2006
- 30
February 23rd, 2012 10:55 PM #2486medyo busy po sa work kaya sa 1k pms ko na po siguro dalin sa casa, btw may recommeded casa and SA po ba kayo around QC? what should i do in my first 1K PMS? should i bring my oil? thanks for the reply sir ,wag po kayo sana mag sawa mag reply saming mga newbies
nice to know na me nakaka experience din nitong 'normal' issue ng ABS , so the SCV has something to do with the ABS? so far hindi pa naman umilaw ulit yung warning light... thanks po sa reply sir
February 24th, 2012 04:19 PM #2487
Mga sir nakalimutan ko pala i mention nung nagpa install ako sa mitsubishi ng hella supertone sabi kahit sila mag install
ma void na rin ang electrical warranty. Sa ibang casa talaga bang ganun void agad warranty eh sila naman nag install?
February 25th, 2012 01:15 PM #2489
lahat ng items pag casa ang nag install dapat may warranty, tama si Ry sila na nga ng install tapos void ang warranty? di puede yun sir. Pano nila na sabi ng void? May nangyari pa after kinabit yung supertone?
*BoyPickUP rear leafsprings yun sir. Just pack it with grease or blast it with high pressure water mawawala yun. May mga grit siguro nakapasok sa leaves. Or you can bring it sa casa may ilalagay sila para mawala yung squeak.
hth
- Sep 2011
- 24
February 25th, 2012 06:14 PM #2490ok na ang leafsprings ko meron sila iadjust un lng tpos oks na.. buti ok ang casa na pinupuntahan ko, walk in agad ako doon.. so far ok nman ang lahat.. MGA SIR KMUSTA NMAN ANG AIRCON NG STRADA NYU? KUMAKAGAT BA ANG LAMIG KAPAG TINAPAT MO ANG BALAT MO SA AIRVENTS? GNUN KC UNG NISSAN NMIN DATI.. DI MAIWASAN I COMPARE KC 1500 PALANG MILAGE KO AT BALAK KO NA ILAPIT ULI ITO SA CASACURIOUS LNG TIA
Monk-owned R53
