Results 2,311 to 2,320 of 5002
November 9th, 2011 04:53 PM #2312
hi...
are you sure sa clutch or engine related yung vibration na napapansin mo?
kasi ako dati may 'vibration sa ilalim' / parang 'tunog eroplano' ako na biglang napansin na nag eemanate somwhere sa ilalim. it turned out di lang maayos yung mga gamit don sa likod ng sandalan. kapag umalog, parang may vibrating sound sa cabin.
first off, try checking it. lalo na yung tire rod baka di maayos pagkakaclip.
under warranty pa ba?
try checking yung battery baka lowbatt na
or try the settings, baka naman naka off or valet mode.
kung sira talaga and under warranty pa, you can bring it to a mitsu casa. or sa winterpine na mismo (not suure w/ the exact adsress, try googling it. madami nang nagpost non dito sa tsikot).
regards,
--292. Marco
November 9th, 2011 07:59 PM #2313
Yung parang metal vibration, sir?
Experienced this also especially when engine is idle. Pero pag-apak mo sa clutch nawawala. Sabi ng mekaniko kulang lang daw sa grasa ang clutch cable sa loob ng rubber boot sa ilalim. Nawawala din a ng tunog pag hinawakan ang clutch part dun sa loob ng boot. It's not really a threat daw pero annoying lang talaga yung tunog especially kung nasa 5K pa lang ang mileage mo.
- Feb 2008
- 162
November 9th, 2011 11:56 PM #2314Additional info lang rin po. if you've tried what the others have suggested and it still doesn't go away baka ito na po.
If the sound you hear is parang, fan belt na naiipit na maingay, the when you press the clutch nawawala yung ingay baka po yung clutch disc. This is what happened to me last August lang po. After tightening all the bolts and fan belts meron pa rin then they finally traced it to a faulty clutch disc that rattles. Kaya po pag nalalagyan ng clutch load nawawala po. Pina warranty ko po and they changed it agad, buti na lang may parts sila na available. Hope this helps.
- Feb 2008
- 162
November 10th, 2011 12:04 AM #2315Tama po si S'Paranoid, if you have time pass by ka na lang sa winterpine, its along Araneta Ave, from Quezon Ave, turn to Araneta Ave going towards SM Centerpoint. Its on the right side a block or two before SM. Kung malayo po kayo and its still under warranty, paschedule po kayo sa casa to make sure may mga techs from winterpine. Good Luck.
- Oct 2011
- 10
November 15th, 2011 12:25 PM #2316
- Oct 2011
- 10
November 15th, 2011 12:37 PM #2317
- Nov 2011
- 7
November 15th, 2011 03:19 PM #2318Hi Guys,
I'm planning to buy a Strada GLX MT next year. However, the engine is still non-VGT. Is there a possibility that Mitsubishi will release GLX-V MT?
Thanks.
- Nov 2011
- 1
- Feb 2008
- 162
November 16th, 2011 12:59 AM #2320By the way how long have you had your ride and was it there before tapos lumakas lang po? Coz normal lang po na parang naglessen ang vibration and tunog ng makina when you press the clutch. Pag medyo nagrattle or very squeaky then I would suggest to have it checked on your next PMS po.
