Results 1,741 to 1,750 of 5002
- Feb 2008
- 162
June 15th, 2011 12:53 AM #1742* S'migs and S'arvin - naku I guess tama kayo and mag ipon na lang ako for another car. Or maybe racechip na lang gaya ni S'ooba99? What do you think. Sir balitaan niyo po kami kung magpalagay kayo. Will the internals of our current engine be able to handle the additional power kaya if we use a race chip? What do you think?
* S'big_bonsai - +1 po. I'm also thinking about changing to Mobil malapit na rin mag 15k yung sa akin. Calling on S'locoroco baka meron po kayo ma recommend na mura mabilhan? I believe I read before someone posted mura lang daw kuha niya in Manila. Mga BOSB's pa share naman po kung saan mura bumili. TIA
June 15th, 2011 10:00 AM #1743The rear passenger side power window of my 2007 GLX L200 is not functioning well when going up but is ok when you want it to go down. Is this an electrical or a mechanical problem with the motor itself na? Anybody experienced this already?Fasten your seatbelt! Or else... Driven To Thrill!
June 15th, 2011 11:56 AM #1744
Guys & Gals,
Check this out! A column from Phil. Daily Inquirer-Motoring Section (Strada VGTs).
5 reasons the Strada is boosting its category | Inquirer Business
- Jan 2011
- 27
June 15th, 2011 12:16 PM #1745
Tsikot Member Rank 3
- Aug 2003
- 1,251
June 15th, 2011 12:37 PM #1746My glx is in the shop, hopefully maayos na nila. I complained of squeaking noise on the clutch when pressed up and down. Ang ginawa ng casa, 2 days kasi kailangan i down ang transmission. They changed the grease on the part of the release bearing retainer. As of now, road test pa daw. Nung pinasok ko, narinig ko yung SA binulong sa supervisor niya na ito daw ang situation sa strada ko, similar problem to the other vehicle na pinasok (inaudible yung type of vehicle, kasi nagbubulong lang), pero ganun din ang gagawin, down transmission.
June 15th, 2011 03:39 PM #1747
binaba ang tranny just because nag squeak?
were you able to experience malfunction on the clutch and the transmission itself?
anong klaseng squeak ba yung narinig mo sir? as in super lakas ba?
- Aug 2003
- 1,251
June 15th, 2011 04:53 PM #1748Sir, squeaking noise siya like those house doors na nagsqueak ang mga door hinges. I sometimes hear those noises on my previous ride, innova. They had to bring down the transmission to access the release bearing (sabi nila). Anyway, I called up the casa, ok na daw. I will pick up the car this 5pm. Walang bayad kasi under warranty. I will get more info kung ano talaga ang nakita nila.
June 15th, 2011 05:05 PM #1749
ahh I see...well its good to know na under warranty....hope all goes well with your truck...
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
