Results 1,731 to 1,740 of 5002
- Feb 2008
- 162
June 13th, 2011 11:06 PM #1731Bumabawi lang po because di tayo makapagattend ng EB. Same here gusto ko rin po ng GPS with backup cam because medyo buwisit mga mayari ng ibang motor, medyo sagad ka na nga paparada isisingit at isisingit pa rin nila ang parada kaya 2 na nababangga ko sa likod whenever I back up. Buti na lang at di nagagasgas si "Spikey".
- Feb 2008
- 162
June 13th, 2011 11:23 PM #1732I've already asked the same question before kaso lang po wala pa po definite answer. I also asked my SA regarding this and ang sabi niya puwede kaso lang palit daw pati loob ng makina because although they have the same engine iba daw ang loob. It was built for higher pressure daw. Don't know if this is true, eto lang po sinabi ng SA sa akin. If you were to ask my own opinion I would have to agree with S'av8or5 na turbo lang palitan. Yun nga lang baka mahal. If additional HP and torque lang rin baka mas mura bili na lang tayo ng RaceChip that is being promoted by tsikot. Plug and play lang then pag nagpaservice ka madali lang daw tanggalin.
- Feb 2008
- 162
June 13th, 2011 11:50 PM #1733As far as I know sir meron pa rin po. Bali nagdagdag lang sila ng GLX-V which is automatic 4 speed na VGT. GLX Manual transmission before was I believe 925k less discounts now its 945k less discounts kung meron pa. You can also check out their website for the updated price list www.mitsubishi-motors.com.ph. Kung taga marikina po kayo try niyo po sa Diamond Marcos Highway look for Frogoso, she's the agent who helped us out when we were buying our ride. Ok siya ka deal, don't forget to shop around the other dealers rin po muna then bargain with her after. Hope this helps and good luck!
June 14th, 2011 02:10 AM #1734
- Oct 2009
- 158
June 14th, 2011 04:34 AM #1735how much po kaya yang race chip? for 2.5 glx will consider this after my warranty ended too.
June 14th, 2011 09:33 AM #1736
Iba internals ng GLX V, If goal mo same power as the VGT Strada, Palitan mo turbo, internals, sensors, etc. per MMPC which will cost you an amount substantial enough to make your jaw drop. )
June 14th, 2011 10:19 AM #1737
upgrading tot he new turbo set up will entail you to make changes to some major internal engine components. the pistons, rins, bushings cam shaft will have to be replaced. tried costing the upgrade a few months ago, and it comes out cheaper to just buy an entire engine set up, because you also have to take into consideration the time and labor that will be consumed when making the changes.
making the upgrade in my opinion is not worth it. just try and save up for the entire vehicle... may warranty ka pa
- May 2011
- 49
June 14th, 2011 11:46 AM #1738
June 14th, 2011 07:35 PM #1739
Meron na po bang update about the 2011 Mitsubishi Strada m/t ? Kung wala pa , kelan pa marelease?
June 14th, 2011 09:04 PM #1740
Mga Bosbs, question lang lapit na 15K PMS ng rig ko gusto ko sanang try Mobil turbo diesel san ba meron nito.. Naghanap nako dito sa Cavite and Alabang wala talago akong makita.. Thanks in advance..!
Daming issue ng SU7:grin:
Xiaomi E-Car
