Results 1,631 to 1,640 of 5002
May 27th, 2011 06:05 PM #1631
^sa winterpine nyo dalin sir....para mas sure, kasi sila din nag kabit nyang alarm na yan eh...hehehe
pero sure ako kaya din nung mga technician sa S4S yan....
- May 2011
- 49
May 28th, 2011 12:07 PM #1632mga bossing between gls 3.2 m/t and the new gls sport v 2.5 a/t which is better? peroformance? fc? practicality in terms sa cost ?
May 28th, 2011 10:43 PM #1633
GLS V- A/T i would choose sir. Practical reason, mas matipid at magaan dalhin. But better yet, you test drive them both so as you can personally tell the difference. Ganyan ang ginawa ko.
- 12
May 29th, 2011 09:50 PM #1634good morning po mga sirs ask ko lang po kung pwede ang 285x70 sa stock na 17 rim? gusto ko po kasi palitan ng A/T ang goma ko. Thank you very much po and more power!!!
May 30th, 2011 01:14 AM #1635
Can anyone refer me to a 4x4 shop (manila area) na expert sa pag-lift? I think I need to have mine lifted a bit cause since replacing my shocks and front coil springs to Old Man Emus, ang laki ng tinaas ng front suspension ko, tapos yung rear hindi nagbago ang height (only shocks replaced at rear), so pantay na pantay na stance niya ngayon. Ano bang hardware ang kaylngan kung papalift ang rear? I know I can opt to change my leaf springs to the OME Dakar leafs, pero d ko muna ginawa kasi baka may cheaper alternative pa. What do you guys think? Any inputs appreciated. TIA.
Also, I finally found the culprit on my "clunking sound" problem.. yung wheel bearings nga, both left and right bumigay na kaya ang lakas ng tunog... Finally, after replacing them ok na siya ngayon. No more clunking sound. Also had my EGR cleaned. Buti nabasa ko dito about the EGR. When my mechanic opened mine, baradong barado na daw. After cleaning, I noticed na mas tumining na ang takbo. Thank God for tsikot forums.
May 30th, 2011 09:59 PM #1639
Newest TSCP member here! Went to S4S kanina, bought a few stuff tapos nagpamember na ako.. Finally, after 3 years! Walang available na club sticker, to follow na lang daw but I was able to get a shirt. Nice. Cant wait for the sticker also.
Nagpalift na rin ako ng rear suspension kanina. 2inch lift lang by replacing the shackles. Lalo pang gumanda ang ride compard nung shocks replacement lang. Solid ang feel ngayon when going through bumps.
May 30th, 2011 10:10 PM #1640
Daming issue ng SU7:grin:
Xiaomi E-Car
