Results 1,331 to 1,340 of 5002
- Feb 2008
- 162
April 8th, 2011 02:24 AM #1331
April 8th, 2011 10:09 AM #1332
Update on 2010 GLS Sport acquired May 2010. It is now at 11,800+ km.
Symptoms / issues of the Strada:
1. Power steering rattle - replaced under warranty
2. Driver's door lock defect - replaced under warranty
3. Uneven height (3.5 mm difference) - dealer will not do anything about it since according to their measurement it's only 1 cm and within spec. Insisted that the uneven height is very noticable, after very long discussion, dealer agreed to make a report. Have not heard feedback (5 months already).
4. SCV problem - Symptoms started to appear at 11T km, parts being ordered. Using V-power diesel so the fuel is probably not a factor, will switch to Caltex after SCV has been replaced.
5. Leaf spring noise - there's just occasional noise but it's not that loud.
April 8th, 2011 04:03 PM #1333
Hi Sir Walter,
My 3.2 L A/T (2009) had a second bout with SCV, nag ilaw uli yung warning light even I use Shell (reg Diesel), The first one several months ago the SCV was replaced by casa with no charge, tomorrow I have an appointment with Mits Casa dahil nga nag ilaw na naman ang warning. The other night I tried to top off diesel, hoping that the light will be extinguish ,still light was on. Now that my warranty is over, I dont know how much will it cost.
Regards,
RTS
April 9th, 2011 01:59 AM #1334
Anyone here tried installing a 2 DIN HU in the middle compartment? Pwede ba putulin yun or tanggalin yung takip to accomodate the 2 DIN?
April 9th, 2011 02:03 AM #1335
Thanks guys! Hoping to join a GT soon. Anyone here from Pampanga pala?
- Apr 2010
- 12
April 9th, 2011 11:41 AM #1336[quote=locoroco777;1717522]sir better if you ask the dealership just to be sure...
Thanks for the reply sir, luckily no need to have the bumper repainted, i just buffed it and i was able to remove the paint off! no deep scratches. Tibay ng top coat :-)
April 9th, 2011 02:41 PM #1337
April 9th, 2011 08:40 PM #1338
Didn't have warning light on when I had it checked. Experience very slight & erratic choking but with negligible power loss. They checked the Strada twice. 1st time, no diagnosis. The 2nd time, left it at dealer for 3 days and they said it's the SCV and they ordered it already.
April 9th, 2011 11:02 PM #1339
Hi Sirs!
We are contemplating on getting a GLX model. I wonder when will the VGT units be equipped with a manual transmission?
And how about fuel stations, which is better? Shell's or Petron's Regular Diesel?
Thank you!
- Feb 2008
- 162
April 9th, 2011 11:29 PM #1340Hello Sir. I believe you can buy a panel for a 2din unit para di po nakausli sa itaas. Ang alam ko po you can get it sa banawe. If you want, you can try Maspro, accredited din po sila ng Montero Club and the last time I spoke with the owner, meron sila doon. Kasya po 2 din doon sa upper slot if you have a GLX unit. Di lang po ako sure sa GLS units. Hope this helps.
Neither's mine. 3 yrs old and no issues whatsoever. Initial 2 PMS lang sa casa, the rest is OC...
Suzuki JIMNY [merged threads]
