Results 1,191 to 1,200 of 5002
- Apr 2005
- 24
March 18th, 2011 11:44 AM #1191Follow up question lang po mga sirs: I find that the rear fog lamp switch for the GLS (the one next to the TPMS display) is always lit, whether pressed or de-pressed. Talaga po bang ganon? Para po kasing counter-intuitive, sanay po kasi ako na naka-ilaw lang yung switch kapag pressed, but unlit when de-pressed. There's nothing on this on the manual po. Thanks ulit mga sir.
March 18th, 2011 11:52 AM #1192
Share ko lang...
Dati Shell V-Power gamit for more than 10 full thanks ok naman...
tapos nag Petron Turbo Diesel ako kasi naubusan ng supply ang Shell for a while... pero napansin ko dahan dahan pahirap ng pahirap umandar makina ko as ginagamit ko Turbo Diesel.
Nung nagkaroon ulit ng Shell V-power, ng shift ulit ako at gradually um-ok siya. Nung mga 4th full tank ko ok na siya ulit Ano ito namimili ng gas yung strada?
PS. naalala ko lang may nag post kasi dati na nag sta-stall strada nya pag hindi shell. HTH
March 18th, 2011 12:23 PM #1193
- Apr 2005
- 24
March 18th, 2011 12:47 PM #1194
March 18th, 2011 01:52 PM #1195
From Mitsubishi's facebook Page
Mitsubishi Motors Corporation will provide the areas afflicted by the Tohoku Earthquake at least 30 i-MiEVs as well as 4WD Triton pickup trucks, to be used for disaster relief purposes. In addition, a donation of 30 million yen to assist the victims and damaged areas.
From mitsubishi-motors.com
Mitsubishi Motors Corporation’s Support to the Tohoku Earthquake Victims Tokyo, March 16, 2011 - Mitsubishi Motors Corporation (MMC) would like to offer sincere condolences and sympathy to the victims of the Tohoku Earthquake. We pray from the depth of our hearts that the devastated area attains recovery as soon as possible.
The MMC group in Japan has confirmed a donation of 30 million yen to assist the victims and damaged areas. As an additional support, MMC will supply vehicles to accommodate the circumstances and needs of local authorities in the area.
In conjunction with MMC's overseas distributors and business partners, we will try to find out the most efficient and optimum ways to render further assistance to those affected.
March 19th, 2011 02:02 AM #1196
There is the new variant Strada 2.5 GLX-V VGT na siya and 4 A/T pa, 4x2 kaya lighter siya so i'm guessing na eto na ang pinakamabilis na Strada ever produced, because of the weight advantage. The price is only 1.030M.
Pero sa top speed kaya mas mabilis kaya yung 4x4 GLS Sport V na 2.5 VGT pero 5A/T? Ano sa tingin niyo?
March 19th, 2011 02:30 AM #1197
adding from LR777's post, the current model offering in MMC Japan would be the double cab, standard length bed format with the 3.5V6+4sp auto as a CBU from Thailand as well. Here is hoping that MMTh can provide MMC Japan with the extended bed/Mega Cab/Single Cab plus Diesel engines for flexibility (IMO).
http://www.mitsubishi-motors.com/pub...etailb318.html
Tokyo, March 17, 2011 Disaster Relief Efforts: Supplying EVs and other vehicles Mitsubishi Motors Corporation (MMC) will provide the areas afflicted by the Tohoku Earthquake with electric vehicle i-MiEV as well as 4WD pickup truck Triton, to be used for disaster relief purposes.
Many of the afflicted areas are troubled with a serious gasoline shortage issue – therefore, electric vehicles have been called upon for its characteristic of being able to run without any specific facility if there is an electricity supply. Also, circumstance calls for vehicle with high road-performance, large cargo capacity and reliable accessibility on rough roads. With these factors in mind, i-MiEV and Triton were chosen to be sent as support effort.
As the first step, 30 i-MiEVs will be shipped out tomorrow, March 18th. Additional vehicles will be sequentially sent out according to the afflicted areas' needs.Last edited by ianmitsulancer; March 19th, 2011 at 02:37 AM.
- Dec 2010
- 6
March 20th, 2011 12:54 AM #1198
March 20th, 2011 07:42 AM #1199
nasa sa iyo iyan if you want to go to the casa to have that fix, ako pinalitan ko nalang saril yung actuator, nasa 300plus yun, mag 1 year na hindi na bumalik and problem, if you go to the casa, usually they just repair it, but babalik ka din sa kanila kasi proven na talaga yung actuator from the powerlocks supplied by winterpine, may defect. if too much hassle for you, just bring it to your trusted banawe shop, papalit mo na para hindi ka na balik ng balik....
March 20th, 2011 06:11 PM #1200
Malakas siguro talaga ang winterpine. Despite na proven na mahina actuator nila, sila pa rin ang supplier ng mitsu
bebe eksa, saan kayo nagchuchurch???
Traffic!
