Results 1,111 to 1,120 of 5002
March 7th, 2011 07:36 PM #1111
March 7th, 2011 08:26 PM #1112
bro, meron akong post dun sa FB natin..
as per advice sa akin ng kakilala ko, first dapat meron kang performance chips and knn filter..
then, pwede ka ng magpakabit ng turbo boost and gauge..
yung boost controller madedetermine kung spooling yung turbo, minimum boost daw ng turbo natin is 8 then pwedeng adjust to 15 or higher.. merong hose na kinakabit sa turbo going to gauge then so on... hanggang makaabot sa boost gauge, di na gagalawin yung ECU...
yung boost gauge naman para ma determine kung nasa anong pressure ka..
hahaha, NOOB lang din ako.. yun lang din inexplain sa akin..
much better si sir DADZ mag explain
di ako sure sa tamang explanation, just sharing..Last edited by nismo26; March 7th, 2011 at 08:31 PM.
- May 2008
- 664
March 7th, 2011 08:35 PM #1113
March 7th, 2011 08:48 PM #1114
- May 2008
- 664
March 7th, 2011 09:18 PM #1115next project natin bro? hehe!
this is what ive found.
http://www.autometer.com/productPDF/608.pdf
March 7th, 2011 10:25 PM #1116
sige sir...kuha ka lang ng magandang brand of AT's pwede na tayo mag roll hehe....may naka akyat nga na 4x2 strada with gov't plates hangang dun sa middle part nung trail eh hehe...
yung kay boy25 yung nakita mo bro....hehe...maaga kami umalis sakanila mga 730am
I still can't get over pa kasi dun sa stuck up drama ko sa laoag sand dunes eh...
dun lang yan sa may san jose del monte sir TC...pwede nating sadyain pag natungo ka dine satin sa bulacan...=)
hehe, di pa kasi naka lift yung akin bro...pinag iisipan ko paring ng masinsinan....parang kasi parang 5 to 6 times a year lang mag tre trail eh versus the other 359 days of the year...
*beniboy, mauna ka susunod ako! hahahahaha!Last edited by locoroco777; March 7th, 2011 at 10:44 PM.
March 7th, 2011 11:47 PM #1117
sorry medyo matagal na to... Pero what can u say about it? eto ba yung parang 'metal-strings sound' na nagkikiskisan?
Napansin ko yng sa akin parang nag gaganyan din, pero intermittently lang. pag napansin ko and papakingan na ng mabuti, nawawala naman.And it napapansin ko lang pag idle. dont know kung it happens habang umaandar.
di din po pla ako nabaha.
salamat
March 8th, 2011 12:14 AM #1118
Sir if you are only concern with the boost you can install a gauge safely but with a manual boost controller will not do any thing good, it is only use to regulate the boost if you are boosting above 20psi, if lower than 20 you dont need a controller. A boost gauge can be installed 2 ways,
1 is to install in in the hose going to the MAP sensor and
2 you can install it in the hose of the waste gate all boost gauge comes with a T-connector for easy installation.
But like what sir nismo indicated you can open the waste gate with the controller to give you more boost.
Just know this the ECU is the one regulating the boost our system have a boost limiter (safety feature), there for the 11 to 15 psi boost will be your top boost.
For tach meter with shift light for shifting if it is manual pwede din siya install only the RPM is need to be connected to the ECU since our trucks is electronic na po you need to get an electronic diagram po nag ECU to determine the right wire where you will tap the tach meter.
Just my note sir hope this give you some info po.
March 8th, 2011 11:36 AM #1119
*LR
ahh akala ko sa kanya, puwet lang kasi nakita ko
nakasalubong ko din yung monster truck ni sir boy25 sa mc arthur lastweek baka galing kila don manolo
ibang klase!
bro txt mo naman ako pag may ganyan kayo na malapit baka puwede ako sumama...gusto kong tumulo laway ko hehe
March 8th, 2011 01:22 PM #1120
i did that, i installed a boost gauge so that i can monitor my boost, rather than rev your engine then uoshift, i look atthe boost gauge and once i see 14psi, that means i have maxed out the power from the turbo, then i upshift. having a bosst gauge is not juss for the rice effect, useful talaga.
