Results 1,031 to 1,040 of 5002
February 25th, 2011 02:04 AM #1031
I finally got a sure answer about that ABS EBD thing..it is NOT a feature on the new VGT 4x2 matic, just for the 4x4. This is really disappointing, but one said some drivers could live without the ABS EBD. Hay naku, do I really need that feature? Hindi naman ako kaskasero, but I will always have this nagging feeling that if ever I would own that strada 4x2 matic, I would feel not so secure and safe.
What's the big deal ba about this ABS EBD mga Bossing? Please help to enlighten me.
Salamat po.
February 25th, 2011 02:25 AM #1032
February 25th, 2011 09:36 AM #1033
February 25th, 2011 10:07 AM #1034
hi sir,
does your present car have ABS and EBD? If you think you really need those two safety features, then you have to get the higher variant or choose another pickup. in the end, its you who will have to drive it and love driving the truck.
I've been driving my Strada for more than 3 years, so far, i never needed to slam on the brakes, but If i had to, I know how to avoid brake lockup. although definitely its a great feature, no doubt.
my other cars have ABS, but when I drive my Strada, I am still secured. but again sir, in still boils down to how you will be feeling when driving your next new car. If its essential sir, no choice talaga tayo but what I mentioned above. HTH.
Basta kami Strada owners, feel secure driving our Strada.
February 25th, 2011 05:43 PM #1036
Just got back from my 5K PMS. Di pala kasama ang oil-change sa 5K checkup pero nagpa-oil change na din ako. Ayun ganda ng ulit tunog ng makina. Yung shifter ko ayus na ulit di na maganit. Kinailangan lang daw i-bleed yung clutch system at lagyan ng lubricant yung sa stick (i think the lubricant did the trick kasi ala naman prob yung clutch).
May montero na naka-display doon. Tinanong ko kung 2011 model sabi nung isang technician oo daw pero paglapit ko 2010 model pa din. Sayang walang 2011 model nausisa ko sana
February 25th, 2011 08:41 PM #1037
- Feb 2008
- 162
February 26th, 2011 01:13 AM #1038Sir ABS is used so that in wet and slippery conditions, when you slam on the breaks you will still be able to control (steer left or right) the vehicle and avoid hitting whatever is in front of you.
EBD naman is usually to distribute the breaking force among all four wheels when breaking. Kasi sometimes we have heavier loads at the back compared sa front and as we all know the heavier you are the longer the distance of stopping, EBD tries to compensate for the difference in weight and will apply more to the wheel with a heavier weight thus equally distributing the break force among all four wheels regardless of weight.
Like my answer before, kung walang ABS driver has to be able to compensate and so long as marunong yung driver (pumping your breaks while steering instead of just slamming on it to avoid lock up ng wheel), same lang ang results compared to it having ABS.
Regarding EBD naman po, you mentioned earlier that you are not planning on carrying very heavy loads naman. If ever meron heavy load po, just remember that a heavier vehicle will need a longer distance to stop compared to a lighter vehicle considering all things are the same po. Again driver experience po kailangan dito.
Just to give you an insight, my old car had ABS and when it broke, I never bothered to have it fixed anymore. Somtimes nga the ABS is quite annoying.
Nasasainyo na po, some of us said that its nice to have but its something we can live without. Hope this helps.
*LR777
Galing talaga ng Strada! Nice video and thanks for sharing Sir. Bakit kaya ganun, yung iba pickup sobrang mausok?
February 26th, 2011 01:16 AM #1039
Sir LR, post ko na rin yung Top Gear article para buong buo ang kwento...
http://www.topgear.com.ph/news/drag-...-nissan-navara
Bili na! But drive safely!
- Feb 2008
- 162
February 26th, 2011 01:19 AM #1040
Discover the ultimate in relaxed romance with the best casual dating platform! Authentic Ladies ...
Exemplary Сasual Dating - Verified Damsels
