Page 186 of 241 FirstFirst ... 86136176182183184185186187188189190196236 ... LastLast
Results 1,851 to 1,860 of 2409
    #1851
    Quote Originally Posted by redshift View Post
    > I also overinflated my tires slightly
    ano po ang tire pressure ninyo?
    #1852
    Quote Originally Posted by carchase View Post
    Sadya po bang hindi nahahapit yung screw sa front plate number natin, rubber kase yung nakikita ko na pinaka thread nya., ganun po ba sadya?
    Hindi ko naman malagyan ng nut in the other end, parang ididisassemble muna yung lower bumper garnish.
    that's right, di nahahapit yung screw.
    i saw one outie where its front bumper was disassembled to have a nut fixed on the other end. okey naman pagkakagawa.
    May 2005
    #1853
    Quote Originally Posted by edok View Post
    thanks guys for posts re: sports mode - will definitely try it ASAP - kaso lang talaga my daily route is matrapik - talk about ortigas extension! hehehehe.
    but i got lots more questions. hahaha. sorry but am really a newbie in manual driving ...
    so at what RPM should i upshift?
    Try upshifting at redline...he he he
    It depends though...for me from 1st to 5th around 3000rpm, then from 5th to 6th 4000rpm. Laki kasi ng rpm drop when I shift from 5th to 6th at 3000rpm...
    Quote Originally Posted by batangmahal View Post
    usually at 33psi...though I prefer a firm ride kasi...:evil:
    #1854
    33 psi. the pressure later goes up after running several minutes. 32 ang recommended ng mitsu
    May 2007
    #1855
    for constant power try upshifting at 4500rpm+, dito kasi umpisa gumana yun mivec actuators ng Outie.
    For economy 2.5k-3k rpm is fine
    Apr 2008
    #1856
    mga sir tanong lang ano ba ma recommend nyo na oil na gamitin ko for outie sa 5k pms? kung fully synthetic 4k+ ang babayadan pa. parang grabe naman kasi ung price, buti sana kung libre lang ng dealer.. hehe. ano ba mga pinagkaiba ng mga oil na un? ano kaya gamitin ko next?
    #1857
    Quote Originally Posted by mykc View Post
    synthetic ang madalas gamit ng casa for change oil although pwede rin ciguro request yun mineral oil or the non synthetic. synthetic oil is the premium oil which provide better protection sa engine. there are other type of motor oil but sa casa most of the time dalawang type only ang gamit nila (minera oil & synthetic).
    Advantages
    The technical advantages of synthetic motor oils include:
    • Measurably better low and high temperature viscosity performance
    • Better chemical & shear stability
    • Decreased evaporative loss
    • Resistance to oxidation, thermal breakdown and oil sludge problems
    • Extended drain intervals with the environmental benefit of less oil waste.
    • Improved fuel economy in certain engine configurations.
    • Better lubrication on cold starts
    May 2007
    #1858
    Quote Originally Posted by MFB View Post
    Do you guys know which bridgestone or goodyear service center (or any tire center) has the specs of the Outlander 08?
    Eversince we got the outie, off center na yung wheel. 2 times na dinala sa casa for realighnment, ayon kailangan pa ng customer participation (that's me) I tried to ask it from them but casa said they dont give out specs.
    My Ford Escape was similar, 2 times pababalik balik sa casa and di pa din makuha. They just gave me the specs so ayon, naayos naman agad sa Servitek. Motor Image (Subaru) also gives out the alignment specs for you car.
    From the workshop manual
    Front
    Camber 020'
    Caster 235'
    Kingpin Inclination 1245'
    Toe-in 12
    Rear
    Camber -025'
    Toe-in mm 3 2
    Hope this helps. Active ka na rin pala sa SCP pre, congrats on your new FXT.
    Aug 2008
    #1859
    Quote Originally Posted by ceepawn View Post
    Front
    Camber 020'
    Caster 235'
    Toe-in 12
    Rear
    Camber -025'
    Toe-in mm 3 2
    Thanks! Where did you get the workshop manual? May ******* download ba yan? Im here at Bridgestone Fort now. Showed them the specs, masyado daw maliit. Differs from what they have here. Same specs lang daw from 03 to 08. Are you part of SCP too?
    Aug 2008
    #1860
    Guys,
    What fuel do you use that works best with the outie 2.4? So far, Im getting good results with Seaoil unleaded. Besides being the cheapest 95 octane e10 fuel, it also passes the highest standards compared to other players. I tried Petron XCS and Shell unleaded, suffered a bit of hesitation.
The 2007 Mitsubishi Outlander [ARCHIVED]
