Page 184 of 241 FirstFirst ... 84134174180181182183184185186187188194234 ... LastLast
Results 1,831 to 1,840 of 2409
    May 2008
    #1831
    Sadya po bang hindi nahahapit yung screw sa front plate number natin, rubber kase yung nakikita ko na pinaka thread nya., ganun po ba sadya?
    Hindi ko naman malagyan ng nut in the other end, parang ididisassemble muna yung lower bumper garnish.
    #1832
    Quote Originally Posted by lymar07 View Post
    bro, 1,180,000 is the discounted price of 1,240,000. less 60k ang discount nilang binigay sa akin nitong october lang. i recommend you go to mitsubishi otis (union motors)...they'll also give you extra freebies look for delvin
    thanks for the info bro!
    Nov 2007
    #1833
    Quote Originally Posted by XXXyzledge View Post
    you're welcome, bro! baka mauna ka pang makakuha sa akin hehe....
    btw, tell delvin that noli recommended you to him
    Aug 2008
    #1834
    guys question/s:
    1. i had my first 1K PMS. The engine oil was changed with a Fully Synthetic Oil (Turbo XP). How long will this oil last? 5K or 10K?
    2. the service agent told me to return on for my 5K service. i'm confused, my odo reading during the PMS was 1.8K, should i bring it back once it hit the 5K on my odo reading or should i bring it back after 5K .. so when i hit 6.8K reading on my odo?
    3. change oil na ba on 5K or wait for 10K since synthetic oils are supposed to be replaced every 10k?
    4. i felt that mejo matigas na yung steering ko .. and also, i had to press on the gas heavier this time after the 1K PMS, is it normal? or naninibago lang ako?
    5. the MIDisplay of my outie still reads that service due for 2,500KM. should this have been reset by the casa during the first 1K mark?
    Thanks!
    #1835
    Quote Originally Posted by edok View Post
    guys question/s:
    Thanks!
    i suggest that sundin mo ang PMS. you can opt not to change the oil during your 5k and just replace the oil filter.
    have your steering wheel check by casa.
    Aug 2008
    #1836
    Quote Originally Posted by meldy12 View Post
    di ko gets yung sundin ang PMS? So i will bring my car to casa on the 5K mark. but oil change is not necessary? just the oil filter?
    how about the indicator sa MID? dapat ba na re-reset yun?
    #1837
    since your last odo reading when you have your pms is 1.8k, you can have the option of either have your next pms at 5k or 5.8. you can request that they dont change your motor oil but only change your oil filter. they may used only one liter of synthetic oil to replace the oil lost during the changing of oil filter (this was an advised of service advisor when i had my pms at diamond motors, quezon ave). but of course, better rin change ka na rin ng oil but since synthetic ang oil used during your last pms, this can still be good for another 5k km.
    you can have your mid reset by casa or follow the instructions found in the manual. hope this will help you.
    Apr 2008
    #1838
    hi guys..just wanna share with you how "sensitive" our outie is..lately..ayaw mag start nung outie..tumawag sis ko sakin at sabi nag flash daw"engine check"....i told her to check the engine...kulang lang ng kaunti water level!....i thought it was something serious pero ok na sya after nagdagdag...has this happened to you guys?..mga 8k natakbo outie ko....
    Aug 2008
    #1839
    hi guys.
    have anyone of you tried the "sports mode" of our outie? i've been itching to try it ... but i wanna hear first hand info on how to use it - rather than rely on the user manual ... hehehe..
    thanks a lot!
    #1840
    hi guys.
    thanks a lot!
    * edok,
    everytime i go on vacation in the phil., i'm using the sports mode during city driving. lots of fun to use.. its like making things harder when the equipment is designed to make things easier (but that was me ). what is life when we will not explore our full potential (or our equipment), di ba?
    on my experience, the sports mode function like this;
    1. using the knob
    - if you are crusing in drive mode (D) say at 50km/hr, once you put the knob in the sports mode position (between the + and - sign), the transmission will be in its current combination based on the current speed. so, its up to you if you where you want to put your next gear (up or down).
    2. using the paddle shifter
    - if you are crusing in drive mode (D) say at 50km/hr, once you click (towards you) either the (+) or (-) paddle shifter, your transmission will simply oblige what your finger are telling it to do so..
    NOTE:
    1. the beauty of sports mode: the transmission will automatically change gear (towards low) once the car significantly reduced speed. its like the computer has predetermined speed-transmission gear combination.
    2. WARNING: in sports mode, during accelaration watch out for your rpm, you might overlook shifting the knob or paddle shifter "gear up." of course it will not shift automatically to next higher gear.
    the basic rule of MANUAL driving still govern..
    guys, did i say it right? or am i wrecking my outie slowly..
The 2007 Mitsubishi Outlander [ARCHIVED]
