Results 1 to 7 of 7
- May 2011
- 12
November 25th, 2011 10:55 PM #1mga boss...plano ko bumili ng HID Xenon light pero hindi ako sigurado kung compatible sa galant gti..meron pa ba mga sukat or compatibility na dapat consider pag bumili or plug and play kahit anong HID light? salamat sa makakasagot
hid xenon light kit
- Mar 2011
- 140
November 27th, 2011 12:57 AM #2Bro,
Don't just buy a plug & play HID hangga't hindi retrofitted yung buong assembly mo (Ballast, Wiring Harness, Xenon Bulbs, Projectors, Lens, Relays, Fuses) otherwise sabog ang ilaw mo bukod sa makakasilaw sa kasalubong mo compromising safety bukod sa takaw away. You better buy a brighter Halogen (Philips XPS, Osram NB, etc. with the same wattage) if you want more light. If you'll just buy a xenon bulb to replace your halogen, sayang lang pera dahil scattered ilaw niyan lalo na pag umuulan...HTH.
- May 2011
- 12
November 29th, 2011 06:27 AM #3
November 29th, 2011 08:18 PM #4
If you're planning on using HID, use it the right way -- retrofit.
If you find these a bit too pricey, since it really is but worth it anyway, then you're better off using Philips Xtreme or Osram Nightbreakers.
The Philips Xtreme & Osram Nightbreakers are halogens, hence glaring wouldn't be an issue unlike when you're using cheap plug-n-play HIDs. The former ( PhXP ) produce a 4300k-like output wherein the light is a bit from the yellowish white while the latter ( OsNB ) produce a 6000k-like output wherein the light it produces are whitish.
H4 prices:
Philips Xtreme - 1600-1800/pair
Osram Nightbreakers - 1100-1400/pair
Banawe QC prices
- May 2011
- 12
December 5th, 2011 01:53 PM #6
sana maganda ang buga ng HID sa glass headlamp ng galant gti mo.
sa lancer singkit kasi na may glass headlamp cover and have the same production year/s ng galant gti ay sabog/kalat ang buga ng ilaw ng HID. pang-clear glass/plastic headlamps lang ata maganda ang HID bulbs.
December 5th, 2011 02:19 PM #7
^ Depende pa rin po sir sa reflector bowl. Maski po clear glass/plastic ang headlamps, sabog pa rin paminsan.
For example, sa Vios pangit ang buga ng HID sa 1.3 J & E, 1.5G pero pag dating sa 1.5XX malinis ang cutoff. Pareho sa Honda Civic FD, sa 2.0S-L, maganda ang cutoff ng HID.
What vehicle and what's your budget?
