Page 6 of 25 FirstFirst ... 234567891016 ... LastLast
Results 101 to 120 of 485
    Jan 2014
    #101
    Thanks for the reply guys, I got the bigger unit na lang, based on your inputs, had to act fast as we did not want to sleep on the floor of our daughter's room tonight.
    What brand did you bought? Inverter or non inverter?
    Nov 2007
    #102
    Hope you didnt buy another carrier.
    2 of our window carriers conked out within 3-4 years.
    Replaced with panasonic and still working after 7 years.
    #103
    Quote Originally Posted by JJB View Post
    hindi naman lahat.
    chempo chempo din.
    our one carrier lasted over 8 years of daily use. the other one is over 10 years old now, but with less daily use.
    our replacement condura is over 4 years now.
    Nov 2007
    #104
    Baka sa model din dok.
    Na-chempo lang na madali nasira 2 Carrier namin with the electronic control with remote. Sabi nga ng AC shop na dinalhan namin na madali masira ang electronics ng Carrier in their experience. Tatagal for sure daw ang manual.
    We also had an LG manual window that lasted 14 years.
    #105
    that explains it.
    we always get the manual-est of manual control aircons.
    Jan 2016
    #106
    Quote Originally Posted by Leo_Arz View Post
    What brand did you bought? Inverter or non inverter?Sent from my iPhone using Tapatalk
    Non-inverter boss, I wanted to buy the inverter pero maliit yung butas at steel cage, so I bought this type na sakto ang sukat para plug and play na lang.
    I bought Condura, but it is an exact copy of the old Carrier except for the brand name. Once I get a bad experience with a brand, hindi na ako umuulit, these brands have the same manufacturer , but maybe, mas alaga ang house brand
    I'll try the Panasonic, when I need the inverters later.
    Sep 2017
    #107
    Di pala standard size yung Hitachi Window type Inverter 2.0 hp...
    Mar 2004
    #108
    2.0 HP window of any brand is usually larger ... also if inverter type, 1.5 HP window of some brands are the same size as 2.0 HP ...
    #109
    Quote Originally Posted by MamBad View Post
    Inverter ACs (any brand) have larger housings based on my observation.
    Jul 2013
    #110
    Main reason manual lagi hanap ko. Bullet proof yang manual controls. Sira na aircon mo, ayos pa din manual controls niyan.
    Dec 2017
    #111
    in your picture with the dead butiki, you already have a white roof. just drill some holes on them, for cooling. then close the sides using electrical tape.
    if it needs real cooling, it'll have a heat sink.
    don't tape over a heat sink.
    I've read that Panasonic and Mitsubishi inverter A/C have their circuit boards coated with silicone to avoid high voltage short circuits caused by lizards and insects. We should have this in mind when buying an inverter A/C.
    Jan 2014
    #112
    Quote Originally Posted by brushless View Post
    Bro san mo nabasa.? Last week nag inquire ako sales person ng carrier sa abenson he told me protected daw yung pcb board. Pero last week posted here thru Lazada seller same question tanong ko wala daw protection yung pcb. Anu para lang makabenta sabihin Ng abenson na protected yung pcb.
    #113
    they can claim anything, as there is no way buyer can verify until after they've bought it, and under threat of voiding the warranty at that.
    in my experience, many of these sales people do not know what's beneath the paint of the items they are selling.
    Dec 2017
    #114
    Here you go:
    "Panasonic claim to have vermin proofed their circuit boards with silicone and said they have few PCB's fried by vermin nowadays"
    Link: Split inverter sizing and geckos - Air con - Home
    "Manufacturers are aware of these circuit board problems. We have read that Panasonic and Mitsubishi Heavy Industries are silicone coating their exterior circuit boards. Maybe this will help. Time will tell."
    Link: Inverter Air Conditioners – we give up on inverters and on Samsung | My Philippine Life
    "MHI have a silicone coating on their pcbs, which sees them hold up to the coastal climates alot better"
    Link: Mitsubishi heavy industries srk71zk - MITSUBISHI AIR CONDITIONERS Consumer Review - MouthShut.com
    "DESIGNED FOR AUSTRALIA: No matter how scorching hot it gets outside, the CSCUS9PKR will keep you comfortable, as it the cooling operation is designed to cope with outdoor temperatures of up to 46°C. While the air conditioner keeps you cool inside, you can also relax in the knowledge that the outdoor units are protected from the elements. A special antirust coating triples the life of the condenser by protecting it from the from the damaging effects of salty air, wind and dust, and a silicone coated PCB (Printed Circuit Board) protects the unit from being damaged by environmental factors such as such as moisture and dust."
    Link: CSCUS9PKR Panasonic Air Conditioner | The Electric Discounter
    I guess from all the brands, only Panasonic and Mitsubishi have silicone protection on their PCBs according to what I've read.
    #115
    so true. minsan basic specs pa lang hindi na alam.
    Dec 2017
    #116
    Re: sales people
    What really irks me is when I asked for a particular item, they will quickly say they don't have those. But, when I looked around, I found it. Count to 10.
    But, in fairness, most are ok. I even ask them to compute for the wattage or the kWh. They know the formula and they know their product. It's totally fine with me if they ask their other colleague if they don't know. I see them as a team. It's only those who quickly give you a "no" answer without even trying.
    Sep 2008
    #117
    Quote Originally Posted by Lew_Alcindor View Post
    Correct me if I am wrong, wala daw manual controls sa window type na inverter?
    Apr 2012
    #118
    Quote Originally Posted by jakewise View Post
    Mukhang wala kasi kailangan sa inverter ay exact temperature
    Sent from my SM-J730G using Tapatalk
    Nov 2017
    #119
    Hitachi meron
    Nov 2017
    #120
    Quote Originally Posted by maxpedition View Post
    Hitachi meron
    Sorry wala pala puro de remote. Pero pwede mo naman pindutin button kung walanv remote
Window type aircon (inverter)
