Page 10 of 10 FirstFirst ... 678910
Results 91 to 99 of 99
    #91
    For small holes you may use PU foam filler, they are easy to work on. You may also use the cheapest silicon sealant.
    Jan 2016
    #92
    This is what I used on my big a/c wall, fortunately for me, come replacement time late last year, I tore it down myself with ease.
    #93
    ^yan ba yun parang foam tape bro? or parang sealant din ang application?
    #94
    Like in concrete mixes, a drier one(less water) would be stronger, more watertight & would shrink less. The purpose for increasing water content is just to make it more workable.
    thanks sa info bro
    akala ko dati standard ang mix palagi, kaya di ako nag attempt mag mix ng cement without a "foreman"
    #95
    We use this type of PU foam spray for the wood jamb-concrete gaps. Good insulator & very stable adhesive, yet easy to remove. It's multi-purpose.
    Jan 2016
    #96
    Ayun, tulad ng sa post ni Sir Travs..
    #97
    ^ That and those GreatStuff brand available at Ace and Handyman even online.
    If not available i'd use the generik silicon sealant less than P50 from the hardware, just buy a good caulking gun i bet that should last forever in your hole/gap sealing needs. Downside of silicon is the vinegar/ammonium smell while curing.
    #98
    oh mahal ito diba? astig yan kasi nakita ko sa vids online very easy to apply nga
    dun ako sa post ni bro 12vdc mas mura hehehe
    Nov 2017
    #99
    Pwede din bosny acrylic sealant wala amoy mura lang less than P150
traditional Aircon or Inverter Aircon
