Results 31 to 40 of 44
May 17th, 2007 07:08 PM #31
Sabi kasi ng isang friend ko when he inquired about it. He was advised to open all windows, basta dapat maganda ang ventilation sa room, because of the higher humidity air that will circulate.
Well, tama rin naman yun e. Hot air absorbs more moisture which will turn the air cooler. And when cold humid air comes in contact with objects, it leaves a minute amount of moisture.
So kung well ventilated ang area mo, there will be some hot air circulating, which will absorb the moisture left by the cold air.
May 17th, 2007 07:17 PM #32
hmm i think its just logical to open windows or doors while using this unit because this is not meant to be the replacement of an a/c unit wherein you close all doors and windows to properly cool the room.
this is just like an electric fan but with a temp cooling feature using water, more so when using the smaller units, kaya ang mga gumagamit nito naka-direct sa katawan ang air just like any fan.
May 17th, 2007 07:21 PM #33
ot na : we yun evaporative cooler thing. it works naman it doesnt naman use mist to cool the room down. theres a fiberglass parang honeycomb panel. a pump brings water to the top and the water drips onto the composite honeycomb panel. as air passes nadadaanan nito yun panel. nun nideliver samin i asked the sales rep. its ok naman daw to put it in a room pero iba pa rin ang effectiveness nito outdoors.
May 18th, 2007 12:30 AM #34
Once you've purchased your A/C you may want to read this:
http://michaelbluejay.com/electricity/
May 18th, 2007 01:03 AM #35
try to open the aircon from the time you stay in the bedroom until you leave in the morning.
do it daily
wait for the bill next month.
kung kaya sa budget, tuloy ang ligaya
kung hindi gamitin mo na lang timer ng aircon. set 1-2 hours depende kung kelan kayo mabilis makakatulog. pag tulog na kayo di nyo na mamalayan mainit pa hehehe
May 18th, 2007 07:06 AM #36
May 18th, 2007 08:43 AM #37
Sir Blue, if you read my post properly it has a question mark "?" so I was asking not saying. di ko kasi alam ang device na sinasabi, akala ko kasi it acts like a Humidifier because there's water involved.
May Humidifier kasi kami dito sa bahay, usually we use it during cold seasons when air is very dry, tapos gagamit pa ng heater kaya pwedeng ma clog ang ilong mo from dryness. I usually pour in a gallon of water tapos naka-on lang over night tapos next morning halos ubos na ang tubig, pero kahit tapat mo ang kamay sa blower niya walang moist na makukuha. Sorry if I miscommunicated.
May 18th, 2007 09:45 AM #38
bakit hindi ka na lang lumipat? delikado pa yan nasa paanan kayo ng bundok, baka mag landslide pa
actually, dahil nasa paanan kayo ng bundok and laguna pa, i assume singaw na din ng hotspring yan, kaya ang init hindi lang nanggagaling sa taas (the sun) pati sa ilalim (hotspring).
maiinit ang lupa tapos mainit ang araw, what a combo.
May 18th, 2007 11:15 AM #40
Traffic!
