Results 61 to 70 of 76
November 8th, 2011 12:10 PM #61
"Strictly speaking, there are no enlightened people, there is only enlightened activity."
- Shunryu Suzuki, Zen Master
To those whose hearts are bleeding for the poor, action is needed not words.
November 15th, 2011 05:46 PM #62
related naman ito sa topic
More Filipino families consider themselves poor–SWS | Inquirer News
MANILA, Philippines — The number of Filipino families who consider themselves poor has grown, particularly in Luzon (excluding Metro Manila) where gloom about worsening conditions has expanded, eclipsing improvements seen in other areas, according to the latest Social Weather Stations (SWS) survey.
The September 4-7 poll, first published in BusinessWorld, found that 52 percent or some 10.4 million households considered themselves “mahirap” or poor, where in June the self-rated poverty was only at 49 percent or 9.8 million households.
Those who said they were poor in terms of food (self-rated food poverty) accounted for 41 percent or 8.2 million households, a rise from 36 percent or 7.2 million households three months ago.
The self-rated poverty rating swelled in Luzon (excluding Metro Manila) to 53 percent, a 15-point rise that erased decreases noted in Metro Manila (39 percent, from 43 percent ), Visayas (53 percent, from 61 percent) and Mindanao (57 percent, from 62 percent).
The rating for Luzon was at its lowest last June at 38 percent since a record 22 percent regarded themselves as poor in March 1987.
On the self-rated food poverty rating, Luzon (excluding Metro Manila) again showed a two-digit surge to 45 percent from 28 percent. Fewer families said they were food-poor in Metro Manila (25 percent, from 28 percent), Visayas (39 percent, from 48 percent) and Mindanao (44 percent, from 45 percent).
The median self-rated poverty threshold rose in Metro Manila (P15,000, from P11,000) and Visayas (P10,000, from P8,000) but declined in Luzon outside Metro Manila (P7,500 from P7,700) and Mindanao (P6,000, from P8,000).
The median self-rated food poverty threshold stayed at P6,000 in Metro Manila and increased in Luzon outside Metro Manila (P4,000 from P3,000), Visayas (P5,000 from P4,000) and Mindanao (P3,500 from P3,000).
The SWS, which polled 1,200 adults, found that 28 percent among the self-rated poor, 16 percent among those who rated themselves “not poor” and 13.4 percent of those on the borderline, experienced involuntary hunger at least once in the past three months.
The survey also found that 31.1 percent of the self-rated food-poor, 14.8 percent among those who rated themselves “not food-poor” and 14.7 percent among those on the borderline, also experienced hunger.
November 15th, 2011 08:42 PM #64
The Parable of the Talents in last Sunday's mass would hit home in a way. The way the priest put it basically: You have to be wise with what is given to you and do something to make it grow. If you don't do anything... screw you (of course he did not say it that way but he did put it that way).
Nakabalik na si Shadow sa doctor for his follow ups?
November 16th, 2011 08:21 AM #65
^^^ Mabuti nga kung ibinaon sa lupa o itinabi,- katulad ng sinabi sa parable...
E kung pinambili ng "load" at pinantaya sa lotto? Paktay kang bata ka... :grin;
14.4K:out:
November 16th, 2011 12:18 PM #66
November 16th, 2011 12:20 PM #67
- 3,754
November 16th, 2011 12:52 PM #68may na basa ako dati.."pag pinanganak kang mahirap di mo kasalanan yon.. Kung tumanda ka at namatay na mahirap kasalanan mo na yon"
Para din ganito "Kung Pinanganak kang pangit di mo kasalanan yon. Kung mayaman ka at pangit ka pa din.. katangahan na yon hehehe"
June 6th, 2014 12:43 PM #69
Buksan ko lang after more than 2 years para ma-remind o ma-moderate si bro.shadow, gamit ang kanyang past enlightenment....
Kaya nga iyong mga walang pang-ospital,- hindi na nagpapa-ospital,- bayaan mo na lang na gumaling ng kusa o mamatay na tirik ang mata....
“Familiarity breeds awe”
23.4K:nerves:
June 6th, 2014 12:55 PM #70
naiisip ko rin yan sir CVT mabuti tayo may pambayad or in my case may HMO, so no problem pag may sakit or kailangan ma ospital
yun mga simplenmg check up, and mga tests sa atin no problem lang check up ng check up sige test ng test pero sila they have to select which one they can afford and which one to delayLast edited by greenlyt; June 6th, 2014 at 01:20 PM.
Since you got this 2nd hand, its a good idea to change the drive belt (its cheap anyway). Also...
