Results 131 to 140 of 163
September 10th, 2021 12:27 PM #132
has anyone here tried using "toggle bolts" aka "butterfly anchors" to mount a TV Bracket on a gypsum board?
2 PCS Toggle Bolt 3/16 x 5 inches ( 5 mm x 125 mm ) Galvanized also called Butterfly Anchor or Wing Bolt TGC | Lazada PH
September 10th, 2021 02:29 PM #133
September 10th, 2021 02:44 PM #134
September 10th, 2021 03:44 PM #135
yes, may steel support yung wall. pero not sure if mag match sya sa available mounts ng TV Bracket.
kung hahanap naman ako ng gagawa. 100% sure akong gigibain yung wall to insert a new bracket.
just to share.
I have 2 TVs. 42 and 55
yung wall mount ni 42 can only hold until 40 inches
yung mount ni 55 can hold until 75
plan ko ilipat si 55inch sa mount ni 40inches, sadly di ko maalala max load (by weight nung bracket)
luma na yung 42inch TV ko and its actually 3kilos heavier than my 55inch TV.
so I think pwede ko na gamitin yung old mounts. worst case, dagdag ako ng screws sa wall using "butterfly anchors"
September 10th, 2021 04:41 PM #136
The tv bracket should screw into the metal studs of the drywall. Its easy to find them by knocking on the wall.
Ideally you get a tv bracket that has adjustable spacing for the bolt that attaches to the wall. These are quite cheap in Lazada or Shopee
Check youtube for “drywall tv bracket installation” most walls in the US are drywalls so there are plenty of tutorials.
September 10th, 2021 07:21 PM #137
- 52,731
September 10th, 2021 09:34 PM #138sukatin nyo po.
many brackets have multiple holes, to accomodate multiple mounting sizes.
gypsum ceilings.
the workplace gypsum board ceilings are sagging because of the weight of the installed public address speaker.
the speaker is not a heavy, high-dollar item. cheap-ish and magaan lang siya, and yet the board sagged after some time.
September 11th, 2021 12:27 AM #139
If the desired or specific TV location won't allow the TV bracket to anchor securely onto wall stud studs, you may build a TV wall of 18mm boards for the bracket to screw on. DIYable if you're handy.
Anchor or hang that board onto the studs securely.
You may gap the TV wall a coupla inches away from the drywall to serve as your cabling cavity.
Pic below shows a similar application. Red arrow points at the TV bracket. White arrow points at the hole to route the power, net, HDMI, audio-video lines or what have you between. Blue arrow=drywall. Note the speakers have no visible wires.
This way, you won't worry of suddenly finding the TV on the floor broken....plus, most of the web of wires will be tucked away for a more pro-like install. Just my 2cents....
- Jun 2015
- 2,751
October 14th, 2021 06:13 PM #140Ano ba ang magandang sealant for polycarbonate roof? Ginamit ng contractor silicone sealant na clear. Looks fine sa joints ng sheets pero parang dumadami na ang leak dun sa portions na nakadikit sa wall.
May alternative pa ba?
Monk-owned R53
