Results 71 to 80 of 795
December 31st, 2018 02:54 PM #71
The CE that designed my structurals also did prep for earthquake, but instead of mat, he did three layers of steel reinforcement for my 2 storey house, he had different number and sizes for levels 0 - 1.5m, 1.5m - 4.50m and 4.5m to 7.5m, I only realized this when I was gearing up for the construction, pretty heavy on budget, as it requires multiple splices. 20mm pa ang gamit sa 1st layer, and all are grade 60.
- Aug 2017
- 870
December 31st, 2018 03:11 PM #72It's really expensive bro. Mine was 25mm grade 70 with certificate for my mat foundation. Then on the second floor 20mm. Then 3rd to 4th till rooftop 15mm (usually Standard size). It's double purpose mini bldg for my bed spacer business
Sent from my iPhone Xs Max using Tapatalk
December 31st, 2018 03:51 PM #73
- Aug 2017
- 870
December 31st, 2018 10:11 PM #74
- Oct 2015
- 300
January 1st, 2019 01:58 PM #76
- Nov 2017
- 1,748
January 1st, 2019 02:05 PM #77
- Aug 2017
- 870
January 1st, 2019 02:54 PM #78Depends sa materials to be use e.g. steel sizes and grade, ready mix cement or manual mixing. Finishing siguro same din from your building plan. Soil test needed first baka malalim bago mareach ang hard part eh additional charges ulit yun coz as you said malambot yung location. If 2 storey residential at sa soil test maganda ang result with 220 sqm there is no need of mat foundation kasi mababa lang yung 2 storey. Mat foundation really recommend sa mga matataas na projects like 4 or 5 storeys with not so big lot area.
Sent from my iPhone X using Tapatalk
- Oct 2015
- 300
January 3rd, 2019 07:50 PM #79Great info, sirs, thanks. I will definitely mention this "mat foundation" with the builder. Malaki din pala difference at makaka affect sa budget per sqm, 5k.
BANNED BANNED BANNED
- Sep 2015
- 13,919
