Results 11 to 15 of 15
- Oct 2014
- 1,232
June 21st, 2018 06:30 PM #11Trouble of using subme pumps is yung stillness nya down there. Which will results into malabong tubig. The good thing is flow rate is very high compare sa jet pumps. If you can fix it securely downside for a try or comparison then, its ok.
BTW, there are jet pumps sold out there na "high heads" for that invert elevation of water surface I think you need high heads jet pump. And also you need "circuit breaker" na para lang sa kanya.
Tsikot Member Rank 3
- Sep 2003
- 786
June 22nd, 2018 03:00 PM #12
July 15th, 2018 12:16 PM #13
there's an issue with the system being presented here... the system will not be in auto mode.
there's a need for a guy to watch when the tank is filled up.
suggest to use a deep well type gould pump. all you need is to use in combination with a big volume pressure tank.
you can adjust the output pressure thru the pressure switch but of course seek the service of an experienced technician.
- Jul 2013
- 2,450
July 15th, 2018 12:25 PM #14My guess is that it refers to water pressure at the faucet. You need the right pump to maintain that pressure just like what our water district provides.
Wrong pump may result in fluctuating pressure especially kung sabay sabay ang gagamit.
Pero kung may tanke kayo, hindi critical yung const pressure, IMHO.
- 52,513
see my pahabol statement above. i mean, i can go on vacation anytime. but my spouse has her...
Traffic!
