Results 11 to 18 of 18
August 4th, 2006 12:05 PM #11
sa US and Canada.. they get billed yata for incoming calls din.. same with incoming text din yata..
August 4th, 2006 12:53 PM #12
when roaming, you get charged when you are called. the caller from the philippines will also be charged, but at local rates only.
Signature
August 4th, 2006 12:58 PM #13
i am not talking about roaming rates.. i meant sa canada and US.. yung mga cellphones nila don.. get charged for incoming local calls..
August 4th, 2006 01:15 PM #14
i was referring to this post:
Originally Posted by StraightSixSignature
August 4th, 2006 01:16 PM #15Originally Posted by Dvorak
- 3,754
August 4th, 2006 02:08 PM #16lahat naman yata ng telco.. nagamit ng int.code... wala lang ma sulat yang writer na yan..
kahit dito sa UAE.. pag nag text ka local text nalabas din country code nila
August 4th, 2006 02:36 PM #17
Dati ang Globe kahit local call (cell to Manila number) you needed 02 or +632.
Ewan ko ngayon.
BTTT, tagal nang ganyan ang GSM. 11 years na yung Globe. Ngayon lang nila napansin. Wala namang kaso.
August 4th, 2006 03:04 PM #18
you still need the 02 or +632 to dial to a manila landline..
pag 7 digits lang.. globe will assume that it's 0917 plus 7 digits.. so babaksak sa cellphone tawag mo..
agree ako syo. battery dying will be the next owner's problem. kaso the only reason I'm buying...
All New Toyota Corolla Cross
