Results 11 to 15 of 15
July 4th, 2006 08:15 PM #12Originally Posted by Heretic
if you lost your 2 front teeth, bridging it would be the fastest and more pleasing appearance compared to a removable denture
fixed porcelain bridge has 3 categories:
1. porcelain fused to metal - semi precious metal lines the porcelain, the downside of it, there would be a gray hue on the margin of your gums and restored teeth due to the metal w/c is bio incompatible with the gum tissue, however you could opt to use gold lining the porcelain though it would be more expensive.
2. all porcelain crown - no metal lining the porcelain, best aesthetical appearance, no gray hues, downside of this, it cost a lot higher but its worth the price.
3. porcelain hybrid (adoro, soldex, integrated abutment crown) - the porcelain is combined with a resin material and some other material which makes the crown less abrasive, if your opposing teeth is a natural teeth and you bite and or chew a lot, you have a mild teeth grinding, this is more recommended, however if a bruxism or night grinding is severe or advance case, then a mouth guard may be necessary to be worn at night to protect the porcelain crown(including all porcelain and porcelain fused to metal)
if you dont want to harm the adjacent teeth by grinding it and reducing its size to act as the anchor for the missing teeth then a dental implant is more recommended, detal implants has 2 types:
1. mini dental implants - w/c has a limited function and limited extent of usage
2. standard implant - w/c is the gold standard as dental implant is spoken off, the difference with mini is the size of implant used, standard implants are the material i strongly recommend though its would priced a bit higher, but the long term result is guaranteed, you can check out www.bicon.com its one of the material i use, and if you are planning to have a dental implant placed, see a qualified dentist or oral implantologist, not all dentist practises or use standard implants=)
July 7th, 2006 10:53 PM #13
i cant send you a private message to you heretic, so im gonna post my reply here:
downtime is about 5 days, however you could go back to work the next day, stiches will be removed within 5-7 days for proper healing, within those period you will have to wear a temporary denture, it could be fixed or removable, untill the implant osteointegrate(the implant binds with the bone) usually this will be like 3months more or less depending on the bone structure and the speed of healing and the osteointegration.
after the waiting period and after the implant has totally integrade with the bone, then a crown could be constructed and attached to the implant.
1. would it be painful? no, during the operation anesthesia is employed, so no pain on the treatment duration.
2. would the implant osteointegrade? yes, but we should allow a healing time of at least 3 months or more as the case may be.
3. would your body reject the implant? no, the material is made up of titanium, and coated with hydroxy apatite crystals (same as the human bone)
4. what are the no-nos? no smoking, before and during and after, if necessary no more smoking especially during the healing phase for this would greatly affect the healing of the implant, no diabetes or heart disease, if there be any it should be controlled.
5. would the procedure be long? no, it would only take 30 minutes to an hour, depending on the case, for your 2 front teeth, 30 mins will do.
July 8th, 2006 12:20 AM #14
cutedoc, yung friend ko problem nya is yung isang front teeth nya patay na ata ang mga veins,so yung color ng teeth naging dark yellow. he wants na i jacket yun na porcelain, you think ok yun? thanks
October 8th, 2010 11:21 PM #15
help!
I chipped my first molar (lower jaw) just now.
can the fillings be done in one visit to the dentist?
I'll be flying to another country for a few weeks (a possibility of getting extended for 3 months) on monday so I may not be available for a second visit to the same dentist.
my tooth exactly looks like this with the dentin slightly exposed.
I don't feel any pain though.Last edited by Negus; October 8th, 2010 at 11:30 PM.
Air Mall or Assembly Grounds * The Rise.
Makati CBD parking
