Results 31 to 39 of 39
January 1st, 2013 02:35 AM #31
Air filters will make a car more responsive. What they won't do, typically, is make it more fuel efficient.
But there are exceptions. One effect of having a different fuel filter or a cone filter on the car is to change the readings of the Mass Airflow Sensor. If the readings change significantly, the filter will produce more power than you would normally expect, and will cause the engine to run leaner, resulting in better fuel economy.
Some cars will adapt, changing the fuel mixture to return it to normal. Some won't. But any change in economy or power is NOT JUIST because the filter flows more air, but because it changes sensor readings, which alters the way the engine operates.
But on cars that use MAP sensors instead of MAF sensors, which rely on pressure instead of air flow, air filters often result in no fuel economy or power gains.
January 1st, 2013 11:32 AM #32
January 1st, 2013 07:41 PM #33
January 6th, 2013 09:38 PM #34
It is all good sir.
One more thing, how about using synthetic oils as compared with mineral oils in improving gas mileage. Is this also a myth?
- - - Updated - - -
It is all good sir.
January 6th, 2013 09:56 PM #35
Depends on the grade. What synthetic does is allow you to make thinner oils with longer life. Thinner oil makes for better fuel economy, as long as the engine can take it.
- - - Updated - - -
January 6th, 2013 11:07 PM #36
And generally,- will old engines take on thinner oils?....
17.7K:santas:
January 7th, 2013 09:16 AM #37
January 7th, 2013 09:31 AM #38
ang paglalagay ng stickers tulad ng TRD, RALLI ART, MUGEN, NISMO, PISTON, FEJODAP atbpang palamuti ay kelan may hindi makapag papatulin ng iyong vroom-vroom.
January 7th, 2013 09:35 AM #39
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
