Results 11 to 13 of 13
May 7th, 2010 04:04 AM #11
Tama lang yan, 1,200RPM for 28 seconds pag start, bababa yan until 550RPM. Depende sa temperature ng makina yung RPM pag cold start. Cold start valve delivers more fuel sa cold start to warm it up faster. Then pagkatapos, patay na yung cold start valve once engine is okay na.
In earlier models WUR (warm up regulator) ang ginagamit. Similar function.
- Mar 2010
- 19
May 11th, 2010 04:59 PM #12guys, quick update. Found the vacuum hose and it is connected to the intake manifold to the gauge... i can now see the fuel economy sensor moving.
bad news is, its always on the red zone of the meter.. have to have the engine tuned 'coz as mbeige suggested, the car's air/fuel mixtures are way out of spec, that why I'm only getting 5 km/liter..
Thanks..
May 12th, 2010 04:29 AM #13
One of the other reasons your car could show bad fuel economy (via the gauge) is due to vacuum leaks. Since the gauge works by vacuum, any vacuum leak will translate to worse fuel economy.
The idle air control valve measures the air flow at idle and restricts it accordingly. This creates a vacuum. If there's a leak, it will manifest in the vacuum economy gauge.
When I pulled the IACV on my 2.6L to clean it, I accidentally cracked the vacuum lines (which are hard and brittle from age). Put them back and noticed better idling, but the economy gauge needle pointed more to the right (worse economy) due to the cracked line.
Start looking for vacuum leaks. If the vacuum leaks check out, then I would give it a full tune up. There is a way to adjust duty cycle PROPERLY and I emphasize this because there are specifications that these engines must adhere to. Otherwise, it will result in increased fuel consumption.
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
