Results 121 to 130 of 164
August 2nd, 2010 06:36 PM #123
Hahaha no, not dropping the ride height. :p Tempting, but no point to it on a Manila daily driver. Damn those sidewalls are fat though hahaha!
By the way these were the tires.
195/55R15 85V. Maybe I should've opted for the 195/50 instead...
August 2nd, 2010 09:50 PM #125
August 3rd, 2010 08:52 AM #126
Walang stock nung Toyo eh. Not at my size and not at my friendly neighborhood talyer at least. Ayoko na mag-order sa distributor at mahal presyo nila.
As for the size, the Kumhos are a different case because they seem to have taller sidewalls than the norm for a given tread width + aspect ratio. I heard 195/50 is the more popular size for those because of that observation.
October 13th, 2012 08:49 PM #127
It's been a while and a lot has happened.
Got a good deal on some lightweight wheels. These are SSR Type M semi-solid-forged rollers, weighing 11.5 lb each at 15"x6.5" +45mm offset. Had to put on 5mm spacers and change to smaller 17mm lugnuts to fit these up front.
A few weeks ago Aibo got the best footwear he's ever had: Michelin Pilot Sport 3s, in the correct 195/50 R15 size. Out went the Kumho Ecsta SPTs, which had worn down to the wear bars. I found them unsatisfactory around Clark International Speedway because of big understeer.
Then I went to the track to test them out...
Scored 3rd in Bracket F at Circuit Showdown Round 8, last October 6th.
Official laptime around Clark International Speedway - Full Course was 2:43.479.
October 13th, 2012 08:55 PM #128
The two rounds of Circuit Showdown I went to in 2012 both took place on Clark International Speedway. Round 4 in June used the West short track; Round 8 used the full course.
You can compare the Kumho Ecsta SPTs vs. the Michelin Pilot Sport 3s around the common corners -- Turns 6 to 15, the ones used for the short track -- in the two videos below. Turn 6 is the one with the large acacia tree.
Circuit Showdown R4, on the Kumho Ecsta SPTs
Circuit Showdown R8, on the Michelin Pilot Sport 3s
October 13th, 2012 09:01 PM #129
Looks like the car's been dropped... or is it just because you're turning?
Car looks good as ever. Wondered what's under the hood?
October 13th, 2012 09:19 PM #130
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
