Results 1 to 4 of 4
- Apr 2009
- 1,902
August 31st, 2010 03:36 PM #1I'm having my valve seals replaced (spark plugs wet in oil) to eliminate smoke belching on mid-to-high rpms.
However, does it still need top overhaul?
Or do I need to do another set of tests? Leak test necessary?
September 2nd, 2010 11:29 PM #2
happened to me once though honda car. replaced valve oil seals and problem solve. no need for top overhaul imo. hth
- Apr 2009
- 1,902
- Jan 2008
- 380
September 4th, 2010 01:10 PM #4You mean 'dukot style'. Once I had also unrealized valve seal problem, though sa diesel engine. My mechanic per experience was telling me, he is almost sure about it, having hard starting and bluish smoke but with otherwise good engine power differentiating it againts the need for the low engine job.
So he removed the head and there in the suspected cylinder were hard cakes of carbon, the other cylinders have but fine carbon soot that is easily remove when touch by hand.
After carefully removing those hard carbon deposit, valve grinding, and valve seal replacement, the engine doesnt even need the glow-plugs to start in cold mornings and the engine is much smoother without the shameful dark smoke.
I also prefer silver. hindi halata na madumi na and some imperfections like faded color and slight...
