Results 1 to 9 of 9
    mga sir san ba maganda mag pa align yung hindi naka off center yung steering wheel, sa ibang alignment po kasi sasabihin ba naman na ganun daw talaga yun na naka off center pero naka align daw
    Quote Originally Posted by rrb622 View Post
    Servitek or Yokohama, they also have a 1 month warranty on their alignment. Pero check muna nila pang ilalim mo at titidnan kung may sira dahil hindi nila i-aalign yan pag may prob yung tie rod, bearing etc ng car mo.
    Tsaka minsan kasi perfect na sa computer pero ang prob sa tire mismo eh.
    Oct 2009
    diba pag inalign eh may nilalagay sa manibela mong brace para na ka center talaga.saka nila i se zero ung align ng gulong mo.
    maliban lang kung may problema na ung mga bushing ar tie rod balljoint mo kailangan palitan muna un bago i align kasi kung hindi papalitan at i aalign lang useless lang din..
    ako may kakilala na sa zafra 300 ang labor.harap only
    ako i do my alignment sa servitek o dun sa shell station sa tapat ng perps sa las pinas.
    Oct 2005
    Pag magpapalit ng mags and tires sa new vehicle...kailangan magpa wheel a align?
    Feb 2009
    The wheels maybe aligned but the steering wheel can be off. This is called over-center-adjustment. It is very easy to adjust if you use steering wheel holding tool while adjusting the front toe. If they say "ganyan talaga" it's because they really don't know what they're doing. Father, forgive them for they don't know what they did.
    Ang trusted ko pag dating sa alignment ay Goodyear Servitek or Bridgestone. between the two, mas impressed ako sa Bridgestone kasi madalas kong nakikita na nagpapagawa ng suspension dun ay mga Subaru, souped up Japanese & European cars. Akala ko noon suplado sila kasi Korean stock lang auto ko, pero they treat everyone equally. Di rin sila mahal.
    Quote Originally Posted by wonderloo View Post
    Mas maige kung pa check mo alignment, camber at caster settings maski wala ka noon nararamdaman sa luma mong gulong at wheels. pag may sira kasi, wala pang isang taon, upod na gulong mo. Rotate tires every 5,000 kms din para pantay ang wear. Sa Servitek, rotation is every 10,000 kms. Personally, I'd rather do %k intervals. P150.00 lang naman kasi.
    brand new vehicle?
    kung ako... hindi.
    unless, may kabig, o hindi kayo makatulog..
wheel alignment??
