Results 1 to 4 of 4
- Jul 2008
- 15
January 12th, 2012 12:59 AM #1hi to all,
ask ko lang kung ano ba yung tire offset? im confuse, im planning to change my stock tire and rim from 185/65R14 to 195/55R15, tama ba yung size na yun para sa toyata lovelife model? ano ba implication pag mali yung tire size ?
any suggestions or recommendations is much appreciated.
drive safely
- May 2011
- 481
January 12th, 2012 12:21 PM #2
there is no such thing as tire offset. there is however, wheel offset. what it is, is the difference between the hub-to-wheel contact versus the midway between the inboard and outboard tire beads. these two planes are seldom on the same plane. the midway of the wheel is more towards the center of the vehicle to reduce tire scrub radius and to put the weight more on the inner wheel bearing than the outer wheel bearing. your tire size change is okay. the front tires more than likely will not rub against the suspension nor the inner fender well
January 12th, 2012 04:54 PM #3
offset -- yung lubog ng gitna ng rim
pag kulang ang lubog may tatamaan pag lumiliko
pag sobra ang lubog lalampas ang gulong sa fender pangit tingnan
positive offset
negative offset
- Jul 2008
- 15
I also prefer silver. hindi halata na madumi na and some imperfections like faded color and slight...
