Good practice ba na ilipat yung dalwa na nasa harap sa likod and vise versa for a certain number of months or year?
Yes sir. There are several patterns on rotating tires. Click link for sample. tire rotation patterns
Depends on the type of tires you are using. And yes its good to rotate the tires every few thousand kilometers to prolong its life..
Ako, every 5,000 kms, or pag PMS. Kung pare pareho wheels & tires mo, including the spare, go for a five tire rotation pattern. With regular tire rotation, you can minimize abnormal tire wear & maximize tire life. Also invest in a good tire pressure guage & always have your nuts torqued. Usually, over tightened yung nuts at pwedeng maputol kung sobrang higpit.
Actually, sa tagal ng driving life ko, ay wala pa akong na encounter na shop na gumamit ng torque wrench sa gulong ko, maybe sa casa, dahil di ko nakikita, pero servitek, bridgestone, yokohama and even the famous Rapide, wala ni isang gumamit sa akin nyan.![]()
sa casa gamit impact wrench. sometimes they use torque wrench like ford. i even asked what setting he used. 90 lbf-ft daw. the manual recommends 100. that's good enough
sa tire shops, walang gumagamit ng torque wrench. tira lang ng tira. that's why broken studs are quite commonso when i have a flat i personally install the spare then put the flat in the trunk. then i install the patched tire myself
I do five tire rotation.... Spare included. It's great to have all same mags including the spare...
I do it every 6 months.
Sa toyota casa per my observation parang ung impact wrench lang ang gamit nila to tighten the nuts, di ko pa nakita na gumamit sila ng torque wrench pag maghihigpit ng gulong.
But one of the local auto repair shops here in our area gumagamit talaga ng torque wrench sa paghigpit ng turnilyo sa gulong. Basta nagbaklas sila ng kahit isang gulong lang for a particular job eh luluwagan nila lahat ng nuts for all wheels at gagamitan ng torque wrench para higpitan. Para daw pare-parehas ang higpit. Sabi kasi ng may-ari ng shop kahit papaano may effect sa "balance" ng wheels at ng sasakyan yung di pare-parehas na higpit ng gulong. At para daw maiwasan yung damage sa studs. Di ko lang natanong kung anong measurement ng torque ang gamit nya.
Kaya sa mga vulcanizing shops pag nagpa-rotate ako ng gulong, advise ko agad sa kanila alalay sa higpit. At di ako pumapayag na gagamitan pa nila ng tubong mahaba pag pang final na higpit na.
Sa goodyear alabang tsaka sa snr tire shop gumagamit ng torque wrench..
But me, i use impact wrench.. i just use the #4 in the torque setting.
Some shops that use impact wrench tightens 1 nut first then do the rest.. but for me i insist that they set all the nuts first then tighten in a cross pattern
Sa Honda Makati one time ginamit nila pang higpit torque wrench yung mahaba ang handle.
Sinubukan ko alisin yung tire ko using yung free tire wrench ng Honda, di ko kaya, kahit apakan ko, ang higpit. Any suggestion guys paano alisin or dalhin ko na lang sa tire shop?
I normally use a metal pipe to extend the wrench. It will increase the torque and help loosen the nut.
Sent from my ONEPLUS A3003 using Tapatalk
