Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
    Oct 2005
    Medyo messy nga ang Tire Gel like from Black Magic at sandali lang naka-kapit kaagad ang dumi.
    I highly recommend these two products...
    303 protectant-very costly pero it will retain your tire color, BLACK
    Some other tire shine products will turn your tires brownish in color specially those foam spray cans, just stay away from those. At ang 303 is semi gloss and not greasy shiny.
    Another good product is from Dupont Teflon. It wont hurt your paint kahit ma-over spray. You know how Teflon works no need to explain here.
    http://www.amazon.com/303-Protectant.../dp/B0000AY69I
    http://us.st11.yimg.com/us.st.yimg.c..._1913_63091176
    Jun 2005
    Quote Originally Posted by bougartt View Post
    Which wont make the tire color fade thru time? I heard kasi tire black or some other brand makes the original color fade later on..
    Thats why i dont use any of this stuff on my tires..
    I don't too.
    Jul 2006
    sir theveed/blackmagic,
    care to share what tire dressing you use in bigberts?
    im using Formula 1 now. spray on.
    medyo mas matagal ang buhay nya compared to the usual tire blocks. i just normally apply it after washing the car, once a week. the shine lasts for a week or so...
    Jul 2006
    Whatever you do, don't ever get Armor All. Nakakatuyo yan ng rubber/vinyl.
    Also when applying, let it sit for a few minutes. Wag mo itakbo kagad. Tatalsik lang yon sa katawan ng sasakyan.
    try Mothers, I use it regularly and it doesn't produce flaking or significant discolorization sa tyre wall. Pahid lang using a rug so you can control the application so in the long run it's cheaper. Formula 1 din ay tried and tested by pros but I prefer the blackness of the latter.
    what brand of tire black can you use for the engine plastics?
    read somewhere that WATER based ones are best for engine plastics....
    Aug 2005
    yung A-toy tire dressing, un naka white na bottle
    been using it for quite sum time ok cya and di oily tignan ang rubber mabango pa/ unlike un tire black
    / 89.75 petot
    Jul 2006
    Yung pinagpapa-carwash namin malapit sa bahay ginagamit na bote ay C2.
    Nung tinanong namin pinapa-chemist pa daw yon. Hmmm...
    Quote Originally Posted by dj_ryankilmore View Post
    / 89.75 petot
    is this water based?...puede sa engine plastics?
Tire Dressing Brands...
